DIY 2005 XC90 2.5T Rear Brake (Parking Brake) 31262874 Overhaul Topic is solved
This topic is in the MVS Volvo Repair Database » DIY 2005 XC90 2.5T Rear Brake (Parking Brake) Overhaul
ALF1
Year and Model: XC90 2003 2.5
Been thanked: 5 times
Post by ALF1 »
Frankly, I changed out the OEM pads when the rear brake discs wore out around 127,000 miles. At that time, I replaced the discs (with are also designed for the drum brake system for the parking brake) and the parking brake pads. The installation was done properly, but the parking brake never worked properly thereafter. At first, I thought it they needed to be worn in. Only much later, when I needed them to work (such as on a boat launch ramp), I went back in. The non-OEM pads without the ground down areas had not worn out. There was plenty of brake pad on them. They simply did not work. It was the Indi repair shop that put me on to the reason why. And when I went to the volvo dealer for OEM, there it was. Flat ground area on round brake shoes.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
1
ALF1
Post by ALF1 »
actually, I changed the OEM rear parking shoes and disc brake pads and rotor using FCP Euro sourced parts at 127,000 miles and assumed they would work. In fact, I was really jamming on the parking brake thinking I did not have enough pressure on it, rather than assume that brand new brake shoes would not work. This frustration went on for 60,000 more miles until I called an Indie shop. As mentioned, they recommended grinding a flat spot on the shoes. Rather than do this, I went to a Volvo dealer and inspected their shoes and sure enough Volvo's brake shoes come with the flat spot already ground into them. So I bought a set and the parking brake worked perfectly and easily ever since.
Has thanked: 1609 times
Been thanked: 4063 times
Added part number to title, great write up !
The flat spot on the parking brake shoes seems to be an XC90 thing only, do go OEM on these
https://www.fcpeuro.com/products/volvo- ... oe#fitment
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
My PAGID brake shoes (see photo on the first page) work just fine.
shoebox
Year and Model: 2004 XC90 2.5T FWD
Has thanked: 7 times
Post by shoebox »
cn90 wrote: 16 Nov 2015, 22:14 DIY 2005 XC90 2.5T REAR BRAKE (PARKING BRAKE) OVERHAUL
Over the years, I have found that after 8-10y/80K+, the parking brake shoes delaminate, the friction material just simply falls off, perhaps due to trapped heat inside the drum portion of the rotor.
No matter what car you own, after some 8-10y/80K+, just do a brake overhaul.
I live in Florida and never use the parking brake. Will never using it mean that the parking brake should still be good? Based on above I'm at 73k with 04 XC90, I should replace, but if I never use it should I be too concerned about replacing it?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
shoebox wrote: 07 Mar 2023, 17:54
Since you do not apply the parking brakes after a drive the heat from the rotor is not absorbed by the brake shoes. I would inspect them first and just use a screw driver to see how well the brake material is still attached. No need to incur the cost nor time if it's still usable. We all know if it ain't broke don't go breaking it trying to fix it.
shoebox
Post by shoebox »
So having the part on hand would be a good idea just in case with the rotor out?
shoebox
Post by shoebox »
I've read that parking brakes can delaminate and seize the hub from a s60 owner, does that apply to XC90?
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Bigger issue is the mechanism that applies the parking brake could seizing up from lack of use. Pads are likely fine.
I need to dig into mine as the parking brake won’t hold and tightening the adjuster didn’t help any.
08 C702.5T (sold)
The non-Swedes:
