EMPI have no kit available for manual Volvo. I checked.Big Will wrote:Hi there. Here are the part numbers you need to rebuild the manual axle:
Repair kit outer turbo all: 31256237
I believe you can easily find EMPI kits in the U.S.
http://www.showmetheparts.com/empi/
That part number is not correct. Picture clearly shows there is a different between the outer boots, one have a hole 33mm size, the other 24mm size. In fact, 31256237 is posted on the first picture, it is the wrong boot for the manual application.
I understand you're trying to help, but giving out wrong information will cause the OP to get more time and money wasted.
