Ozark Lee wrote:If the compressor grenaded internally then the whole system needs to be flushed. According to Jimmy, you can't flush condenser coil so it would need to be replaced. The flush chemicals are pretty expensive but at least they have them in a version that doesn't require a whole flush kit and an air compressor.
If the compressor will still "turn on" is that a good sign it might not have completely imploded?
That would be great, once the snow stops and I can get out there I will kinda see how much play I have in the pulley now. I have AAA too if I try to get there and it failskahl wrote:I have a serpentine belt that will bypass the compressor. If you can get up to Delaware I will help you put it on if needed.
