Need advise NW Ohio/SE Michigan
JRL
- Year and Model: Several
- Been thanked: 16 times
You either have a bad TCM or a shorting out when hot wire from its harness
jforce
- Year and Model: 1999 Volvo S70
well I must agree, i do get better response here thanks!polskamafia mjl wrote:Agreed. I would argue one of the best car forums period.abscate wrote:
Many of us don't bother with other Volvo Fora - because, well, the best one is here...
1999 Volvo S70 Silver Sands Metallic, 200K - recent purchase
1997 Volvo 850 T5 Turbo, Nautic Blue Metallic - deceased
jforce
abscate wrote:I did a little digging on that P1618 code and its an internal TCM fault that trips and ECM fault, that turns on your CEL...
This might be the entire problem, but its depressing that Volvo can't tell you that because the TCM codes are their domain.
I think we need to get you someone with VIDA nearby.
I don't know if TCMs are married to the car like the ECM on a 1999 CANBUS but Henry and Mike will know that.
Well, that is less than helpful.....TCM-0039 is a ghost code. Because its the only TCM specific code, and there are no other TCM specific codes, the recommendation of the dealer tech (go figure) is to replace transaxle as a unit.
I wholeheartedly agree abscate...!
jforce
TCM is married to the vehicle right? Because we have to send an old one and a salvage part of same part no to XemoDex to replace one, correct?
jforce
OK, I was thinking about that too...because right now, I'm down toJRL wrote:You either have a bad TCM or a shorting out when hot wire from its harness
1) Junking the vehicle/selling it with a blown tranny for next to nothing
2) Installing a salvage transmission myself, but admittedly not knowing how to buy one or even if that will solve the issue because if its electrical then its for naught
3) throwing parts at it....as in a new TCM.
What would be a way to check the TCM?
How best to buy a salvage yard transmission? What do I need to do? What questions do I ask? Is there a place you forumites go to and trust? Do any of you local have one??
jforce
Thanks JRL, I have another friend who agrees with that.JRL wrote:You either have a bad TCM or a shorting out when hot wire from its harness
However, the 'whining noise' happens each and every time once it warms a little bit and in concert with the appearance of the flashing arrow and the CEL. Whining = pump cavitation, no? If its purely electrical then whats causing this whine? Almost sounds like its coming from ABS but as you can see no codes, no dash lights, no tracs light....you know I never did put a pipe or something on the ABS when the whine occurs, perhaps I should do that....
Everything on these cars is controlled electronically. Once a TCM is compromised, the transmission won't run well.
jforce
So then you guys recommend addressing the TCM and not the tranny? Car is still at Volvo. I could have them check all the TCM connections. Thoughts on that?
- Has thanked: 2200 times
I am a great believer of trying the simple stuff first. It is worth having the TCM pulled and making sure all the contacts are clean. I have heard of them occasionally acting up as they get corrosion on the contacts. Didn't see if this had been done already.
jforce
Thanks. I have not pulled the TCM and cleaned contacts yet. Do you guys have a preferred contact cleaner you typically use?
- 547 Views
Last post by 850oldschool
- 455 Views
- 14 Replies
- 1988 Views
Last post by kaneelschep
- 14 Replies
- 2684 Views
Last post by vtl
- 1125 Views
Last post by j-dawg
