Heater is not blowing very strong.
tboothe33
Year and Model: 2007 XC70
Post by tboothe33 »
chrism wrote: 13 Feb 2019, 11:12
tboothe33 wrote: 13 Feb 2019, 10:34 I had the heater core replaced in 2017. Well, wouldn't you know, I hit a pothole 2 weeks ago, and the heat went out again. Since my heater core is relatively new, is there something that could have come loose when I hit the pothole? It worked fine before I hit it.
I wonder when they replaced the core if they disconnected the little linkages that open/close the blend doors and didn't get them reconnected properly. Then when you hit the pot hole one of them jarred loose???
They're the two flat metal "arms" in this photo:
download/file.php?id=3384
Did you lose heat on both the driver's side AND the shotgun (passenger) side?
Yes, both the drives and the passenger side. The car itself heats up fine, but no heat coming out. When I switch from "auto" so front fans it makes a really loud kind of noise.
07 V70 XC (mine!)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Each side has its motor and linkeage, don't think it's a motor issue. Maybe the blower motor has an issue? Does the noise come from behind the glove box?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The arm that moves the flap is Volvo PN 9171544 ($25 from Volvo dealer or online).
I detailed my experience when replacing the heater core in my 2005 XC90 2.5T in the DIY below.
You can easily inspect the arm with minimal tool:
viewtopic.php?t=82726
