98 s70 GLT Misfire
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
When I replaced the spark plug wires, cap, distributor, and plugs on my 98V70 T5 I got misfires as well. I was using bougicord wires, bosh cap and distributor with correctly gapped OEM plugs. I fixed the misfires by CORRECTLY adding a small amount of dielectric grease to plug / wire of the cylinder that was misfiring. Not sure if this will work for you but it did for me. See this youtube video for the correct way to apply dielectric grease to your spark plug wires.
Hope this helps... keep us posted on how the repair goes.
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
Has thanked: 311 times
Been thanked: 818 times
Post by erikv11 »
Autolite makes hundreds of plugs, which one did they sell you? The part number.
samtron6
Year and Model: 1994 850 non turbo
Post by samtron6 »
thank you all for the help.... charleskennedy23 i will try that once it stops raining only day off and its raining HA... um erikv11 it is autolite copper 3923 hope that helps
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Sounds like an intake air leak.
Post by erikv11 »
Yeah OK that 3923 Autolite plug should be fine on a 98 LPT, gapped 0.028 to 0.030. Check into Robert's intake idea too.
samtron6
Post by samtron6 »
well it finally stopped raining for 5 min lol so i put the dielectric grease on all 5 boots drove for almost 2 hours and everything seems fine now and plus got my power back too i hope it stays that way lol will tell in the morning on cold start up thank you all again will keep ya'll posted
charleskennedy23
Nothing like simple solutions... Glad it's working out :D
Charles Kennedy
Post by erikv11 »
Awesome. Great suggestion, Charles.
samtron6
Post by samtron6 »
well just went to the store and not even 2 minutes driving the bitch showed up again LOL meaning the CEL random misfire now and misfire on cylinders 2/4/5 again cleared and drove another 20 minutes and nothing this is weird drives like a champ no air leaks nothing... how does it misfire after doing a tune up ?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Re-install old spark plugs and wires and see if problem persists.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
