Significant differences between 1999 s70 glt vs. 2000 s70 glt se
jmorman
Year and Model: 2000 s70 GLT SE
Post by jmorman »
I’m looking at a second s70 to use as a donor/Frankenstein.
Are there any big differences between a 99 glt and a 2000 glt se?
Has thanked: 2196 times
Been thanked: 1850 times
Can't think of much if anything. The SE was a 'special edition' which just had some options fitted as standard, or in the case of mine had no moon roof!
Some 99-00 models could have changes like the base model (non-turbo) changed from a 4 speed to 5 speed auto. 'R' models went to a 1 year only rear brake option, and some AWD models could have changes to the prop-shaft.
Can't think of anything else. Other's like abscate may know if there is anything they have come across.
Has thanked: 1609 times
Been thanked: 4063 times
I think you will have Exhaust VVT on both cars, new style ignition switch on the 2000, and Prince didn't care about the 2000.
"Maybe Im just like my Volvo, too old....."
jmorman
Post by jmorman »
The seller was kind enough to share the Product Identification Plate. The important parts match up except the codes are different for the “front suspension spring and strut code”
A quick check of a few websites shows that the strut assemblies are interchangeable so I am guessing they might have used a strut with different specifications but still interchangeable.
