should the A/C compressor be on all the time when set to min?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I know that Volkswagens disable the AC at 4 oder 5 degrees Celsius to prevent failure from water in the system that could freeze. And VW makes the ice Symbol in the dashboard go on at that temperature as well.
So since Volvo turns on the ice warning led at 2 degrees it might be the same temperature the AC stops working.
1996 855 R,
2010 V70 D5,
Has thanked: 1610 times
Been thanked: 4065 times
Does defrost mode override the temperature limit on AC? We haven't had enough freezing days this winter for me to remember..
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Nope.
Heater fans are going on full speed,rec is on without light on by default...and everything seems like ac is on,BUT because of low outside temperature(below 2 degrees Celsius) compressor is not switching on.System is designed that way.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Well I've learned something today.
misha
Post by misha »
:mrgreen:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
