1996 850 N/A PCV - Flame trap
- Has thanked: 311 times
- Been thanked: 817 times
You may be interested to know that by 1998, Volvo eliminated the flame trap disc, even though it is the exact same engine and PCV piping.
Teddy1975
- Year and Model: 2007 V50
- Has thanked: 1 time
- Been thanked: 7 times
And I just found out why they eliminated the flame trap, from this service notice in VADIS... (This program have a world of information, just have to learn how to use it properly):
I thought it was simply because people thought it was not necessary to have the flame trap that you guys said to just not install it. Now you can tell others exactly why they should rip out the trap first thing they see it installed in their car.
And a slap on my wrist for not listening to you sooner.
So since I live in a country where there's at least a chance of snow 3 months every year, I'll not install the flame trap and just get rid of the one I bought.Crankcase ventilation, service
Note! Winter driving and short journeys can cause build-ups of ice in the flame trap. In severe cases, this may damage the crankshaft seals. Therefore the system must be cleaned thoroughly.
Remove the cover over the throttle pulley
Release the hose clamp for the inlet hose on the air cleaner (ACL) housing.
Disconnect the hose from the air cleaner (ACL) housing. Bend the hose forward slightly.
Remove the oil filler cap
Clean the crankcase ventilation and/or remove the flame trap
Remove the flame trap by twisting it approximately 15 mm to the left (bayonet socket).
Clean the flame trap housing (2) after the flame trap has been removed. Blow the hoses clean 1&3. Clean the inputs and outputs for the multi-nipple (4). (does not apply to 1995 models)
Note! The nipple (3) for the small hose has a 2.5 mm diameter calibrated hole. (Use a drill bit for cleaning)
Caution! Do not disconnect the hoses from the flame trap casing. Altering the hose positioning can affect the throttle function.
Reinstall the components
Reinstall all the components except for the flame trap.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Others already know.Teddy1975 wrote:...I'll not install the flame trap and just get rid of the one I bought.
I thought it was simply because people thought it was not necessary to have the flame trap that you guys said to just not install it. Now you can tell others exactly why they should rip out the trap first thing they see it installed in their car...
It's allready explained over Volvospeed board a long,long time ago.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Get rid of it because it gets clogged up. Oil, ice, whatever ... yes a clogged flame trap can cause crankcase pressure and blow seals.
(This site have a world of information, just have to learn how to use it properly.)
- 1694 Views
Last post by 93Regina
- 716 Views
Last post by Ozark Lee
- 1489 Views
Last post by callahanoffroad
- 12 Replies
- 2586 Views
Last post by erikv11
- 707 Views
Last post by GlennG2759
