Still overheating - 98 V70 T - sudden coolant loss
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Replace coolant reservoir cap. There is a defective seal that is keeping the system from pressurizing correctly. That will cause the coolant to boil out of the reservoir without leaving any trace of a leak.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- nickelghandi
- Year and Model: 1998 Volvo S70 GLT
- Has thanked: 14 times
- Been thanked: 3 times
I just had mine done for a similar head gasket leak. I could not confirm it with the combustion gas in coolant test or a compression test, but eventually dyed and pressurized the cooling system and found a small amount of coolant in cylinder 5. Had a slight miss in cylinder 5 a few months ago, but it went away when I fixed a broken vacuum line so I figured that was the issue.broken08 wrote: 30 Mar 2017, 12:09 I have a local shop ready to do a head gasket for $1600, maybe more. Would you do it?
What would you do?
My total came to $1669, but I recently had timing belt, idler pulley, and water pump changed. They redid the timing belt and idler pulley just because I couldn't locate my records to prove it and they wouldn't warranty the work if they didn't do it and I couldn't prove it.
I would do it for a 98 T5 in a heartbeat. I did it for my 98 GLT without hesitation. 98 was a great model year for these cars.
By the way this is my first post, but I've been lurking on these forums for a little while and using rspi's YouTube videos to guide some of my DIY repairs. I am almost to stage 0 and once there, I will start working on the paint and other little things that irritate me, but don't affect driving.
-Nick
- Has thanked: 312 times
- Been thanked: 818 times
Last we heard it was losing coolant, it sounded like a head gasket but still nobody knew why. Did the shop determine the head gasket is bad, combustion gas test or some other method? Or you just took it in for a quote?broken08 wrote: 30 Mar 2017, 12:09 I have a local shop ready to do a head gasket for $1600, maybe more. Would you do it?
What would you do?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
What brand water pump? Reason I ask is VW used to have some with plastic impellers - when they got hot the impeller would rotate independent of the shaft... Only seemed to do it at the worst time.
2023 Lexus RZ450e -66k
- 480 Views
- 3444 Views
- 644 Views
Last post by volvolugnut
- 484 Views
Last post by Faust
- 905 Views
Last post by 93Regina
