'98 V70 dash gauge lights out Topic is solved
- kippster41493
- Year and Model: 1994 850
Possibility of loose bulbs as well. My clock, temp, MPG, etc. LCD screen has loose bulbs (I knocked them loose re-installing the cluster) and when I hit bumps in the road, either they will go out completely or come on half lit/ fully lit.
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
So on my recent trip to the PnP, I grabbed a potentiometer and an actual headlight switch. Since the parts were so cheap, I swapped out both. Gauge lights now stay lit and do not flicker. I don't know whether it was the potentiometer or actual light switch that was bad, I'm just happy to have a fully functioning dash again.
Neil is quite correct about having to be super gentle in removing the potentiometer because of the offset spring clips. I removed mine from behind after pulling the rear fog log switch. I went in through the rear fog light slot in the dash and eased the potentiometer out from behind. It is still very easy to snap off the plastic holding the spring clips to the switch body as my efforts to retrieve potentiometers from the PnP taught me.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Thanks for closing / solving this.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- E Showell
I think Misha nailed it, but it could have been the actual light switch since I changed both at the same time thus failing to isolate the variables.
'95 855 auto (sold)
'95 855 auto (sold)
- 2879 Views
Last post by 98v70dad
- 353 Views
Last post by mitchmoney6
- 854 Views
- 484 Views
- 6488 Views
Last post by 93Regina
