Look what I did to my 1998 V70XC
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
scot850 wrote:Check the oil you are planning to use for the trans. I believe that is wrong for a 98.
It's fine, I use it all the time and it's compatible with the spec ATF for this trans.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
shiloh51933 wrote:
Clemens wrote:Oxygen sensor. Interesting. One thing i really avoid to replace whenever possible cuz in my heart i am cheap...
The wires and rotor and cap will make it mich smoother. At least they did that to my R
Actually I didn't pay for the o2 sensor this time, I exchanged the defective NTK o2 I purchased last June. They ordered the wrong size NTK o2 sensor, so instead they gave me the Bosch o2 that they had in stock and it just happens to be original equipment.
I have 4 quarts of Aisin Warner ATF(3309) that's going in for a drain and fill.
The transmission takes more than 4 quarts, and Type 3309 is not compatible with Dexron - so don't mix the two. Mobil tech support says they are not compatible.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
shiloh51933
  • ko
Its a drain and fill, so 3 to 4 quarts and this ATF is what is used from the factory.
shiloh51933
I must make a correction on this thread, I confuse our Cross Country's sometimes. My wife's'04 is a 5speed a/t that's uses 3309, I used Aisin Warner ATF but it does not say 3309 on the bottle. It's the OEM manufacturer of a lot of the a/t in Volvo vehicles and OEM ATF used in some Volvo's.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
The manual for that year specifies : ATF Dexron IIE/ III and Mercon
shiloh51933
No Regardless JWS3309 is backwards compatible with Dexron III.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
shiloh51933 wrote:No Regardless JWS3309 is backwards compatible with Dexron III.
Apparently you can't mix them though!!! Beware!!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If you flush it but I would not mix them
shiloh51933
Dexron III is a synthetic blend right, 3309 is full synthetic right. If this is true then adding some full synthetic to a synthetic blend shouldn't harm anything but I could see why you might want to keep them separate.
JRL
Post by JRL »
3309 is a mineral oil no synthetic whatsoever
