Timing Belt change - 2010 V50 1.6d DRIVe
- Has thanked: 17 times
- Been thanked: 35 times
It is rather odd that the cam sprockets landed in the same spots before. I had never heard of this. They should actually land randomly. Of course, if you need to work through the sprockets, you can always turn the crank shaft with a large socket wrench. Is there a reason you are questioning the timing? If it was off, you would 1) not run at all 2) run roughly 3) have a check engine light on for one or both of the cams being off... Post back to let us know if the car runs properly now.
- 5070 Views
Last post by jimmy57
- 8281 Views
Last post by pierremcalpine
- 5290 Views
- 23 Replies
- 17237 Views
Last post by jonesg
- 20 Replies
- 17462 Views
Last post by Hurtfeelings
