Heater Core odor?
- Been thanked: 4071 times
I think they do wash out ok, and many have been happy with the part, so if you do take the part out, you can get rid of the problem pretty easily.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Yeah it was discouraging for me too!! Had postage been less than the cost of the heater core I would have claimed on the warranty.
- Has thanked: 2205 times
Try the hot burn off and then you could try one of the A/C cleaners through the system. They are like a grenade, you hit the top of the can and leave the engine idling for whatever the specified time, and hopefully you will have a fresher car afterwards.
Geevs
- Year and Model:
- Has thanked: 9 times
- Been thanked: 2 times
I installed the eBay heater core from *swedish*auto*lamps and unfortunately I didn't put through a dishwasher and now getting the funky smell. I evacuated all the old refrigerant from the AC system when I took out the engine from the car for a rebuild but did not refill the AC system when the engine went back in. Would an empty AC system compound the problem?
The smell is mildly nauseating - is it toxic? Had to drive with the windows down, vents closed, recirc ON and blower/AC OFF.
I would like to try the trick to run full heater with AC OFF for a prolonged period of time.
Thanks!
Thanks!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Was it one of the new "black" ones or the old cream colored ones? I usually was them with degreaser which seems to work fine.Geevs wrote:I installed the eBay heater core from *swedish*auto*lamps and unfortunately I didn't put through a dishwasher and now getting the funky smell. I evacuated all the old refrigerant from the AC system when I took out the engine from the car for a rebuild but did not refill the AC system when the engine went back in. Would an empty AC system compound the problem?
Thanks!
It might be worth the hour that it takes to remove and clean it.
- dorvin
- Year and Model: 1997 Volvo 850 T-5
- Has thanked: 1 time
- Been thanked: 4 times
I replaced my heater core with an aftermarket one last winter, and now that the cold is setting in finally this year, I'm still getting an odor for a minute or so after turning up the heat. It subsides fairly quickly, and I've just learned to live with it.
The AC charge won't impact the heater core smell. I don't think anyone knows exactly what the residue is but car exhaust from the vehicle ahead of you is probably more dangerous
Geevs
- Year and Model:
Hello again, it's been almost 9 months since my last post above and I'm still getting the funky smell during the first few minutes. I've run the heater and A/C system for half an hour in the beginning of the year and it did help a bit. I thought by now the smell would have been totally gone. I guess I will have to yank the core and give it a good wash. Dishwasher is not an option due to the missus. Any suggestions on how to give it a good wash by hand? Should I soak the entire core in a pan filled with all purpose cleaner for a few hours and then rinse? Which cleaner/degreaer did you use? Thanks!
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
I used the powder that we use in the dishwasher in a bucket of really hot water and let it soak for a few hours.Geevs wrote: 12 Sep 2017, 10:36 Hello again, it's been almost 9 months since my last post above and I'm still getting the funky smell during the first few minutes. I've run the heater and A/C system for half an hour in the beginning of the year and it did help a bit. I thought by now the smell would have been totally gone. I guess I will have to yank the core and give it a good wash. Dishwasher is not an option due to the missus. Any suggestions on how to give it a good wash by hand? Should I soak the entire core in a pan filled with all purpose cleaner for a few hours and then rinse? Which cleaner/degreaer did you use? Thanks!
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
kaneelschep
- Year and Model: '96 850 2liter t5
Strange.. I replaced mine 8000km ago with a nissens and it didnt stink at all..
- 11 Replies
- 9869 Views
- 5092 Views
- 32 Replies
- 17798 Views
Last post by sleddriver
- 702 Views
Last post by jreed
- 13 Replies
- 2389 Views
Last post by 93Regina
