'98 V70 base, FWD, 5 speed. Bearing Scratchy Sound
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
An automotive stethoscope may give you better accuracy versus the hose method. I think they're cheap and even at harbor freight too.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
I would take the serpentine belt off and then listen.
If it is a bearing in the tensioner, alternator, compressor or ps pump, it will go away. If the noise is gone spin these components by hand and listen / feel.
Hope this helps, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Never removed the serpentine belt (I guess I must have years ago for some cylinder head work but have no recollection of same). Big job?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 2199 times
Been thanked: 1852 times
It isn't too hard Evan. On the serpentine belt tensioner there should be one of 2 methods to 'un-tension'. Look on the tensioner for a square hole. There is a long lever you can buy cheaply that inserts into the square hole to allow you to de-tension enough to remove the belt. The tool below from IPD also has a wire lever that then locks the tensioner out of the way by passing through 2 holes when aligned:
https://www.ipdusa.com/products/5830/10 ... -belt-tool
You can also use a 1/2" or 3/8" (can't recall) socket wrench for this but it may not give enough purchase or may be too deep to get access between the tensioner and the inner fender.
I seem to recall buying a tool cheap at Princess Auto in Canada, but your equivalent would be Harbor Freight. A sturdy nail will do for the locking tool.
Later tensioners use a Torx tool to do this job in place of the handy square hole. Then you need a stubby Torx socket (T50?) to do the job.
#1 thing to do first is to take photos of the path of your serpentine belt as there are 2 ways this can run. The original and the augmented contact at the alternator. Either way take pictures of the route!!
Good luck!
E Showell
Post by E Showell »
OK so, I made a plumbing cap serpentine belt release tool and have managed to remove the serpentine belt. I have spun the pulleys by hand. Power steering pulley seems OK. Alternator pulley OK as well. Tensioner & idler seem OK. I cannot turn the a/c compressor pulley by hand. Is that how it should be, or should that pulley spin freely as well? I haven't started the car without the belt yet. I was waiting for someone to weigh in on this post. I am fairly certain that I know the answer to my own question -- but hey -- you can't turn the crank pulley freehand. . .
Also, it will be at least a week before I can get to the a/c compressor repair. Can I leave the tensioner locked in the released position with a locking pin inserted, or should I remove the locking pin and allow the tensioner to return to the "at rest" position?
'95 855 auto (sold)
Has thanked: 1609 times
Been thanked: 4065 times
The front of the AC pulley is attached to the compressor innards and won't turn
The ridged pulley part should freewheel, if it doesn't.....asked and answered, Counselor.
I wouldn't sweat leaving the tensioner in.
E Showell
Post by E Showell »
Ridged part of a/c compressor does not turn. Compressor is toast. I'll see if I can score a good used one at Harry's. Steve -- I may be headed out there next weekend.
'95 855 auto (sold)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
C'mon guys either buy or borrow a (automotive) stethescope
