Rate your skills - the official MVS poll
I am a (blank) Mechanic
Poll ended at 14 Sep 2016, 16:46
O Rivers - I can't even pump my own gas (with apologies to NJ residents)
1
1%
1 River or Beginner - I can perform monthly checks of dipstick, coolant level, PS level
1
1%
2 Rivers - Basic - I can do an oil change, Change a tire, wiper blade, fuse, relay, lights
5
6%
3 Rivers - Mechanic I can do a full brake job, driveshaft, PCV, fuel pump
45
57%
4 Rivers - Advanced - Top end of motor, bottom end of motor, drivetrain - can often find better ways to do things than 'the book'
25
32%
5 Rivers - Expert - You know who you are. The few, the proud - mike, jimmy....and less than 10 others..and not me.
2
3%
Total votes: 79
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
Solid 3. Hope I never have to attempt level 4!
DeathRex
Year and Model: 1996 850 Turbo
Post by DeathRex »
E Showell wrote:ET -- Extreme Turd? ( I kid only because I thought abbreviations were frowned on in forum rules).
Electronics Technician
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
I'd called myself a #4 only because I am so new to Swedes, but in all reality I am a closer to a 7 or 8 when you take into consideration my other "money suck".
A completely scratch build Lotus Super 7 replica. Known otherwise as a LoCost 7. It's got a VW 1.8l FWD lump mated to a T3/T4 with a Megasquirt v3 ECU and TechEdge WbO2 controlling it. A Toyota W55 Trans. A Subaru diff and rear suspension. Chevy Beretta front uprights and custom designed Suzuki R1 Inboard Pushrod suspension all around. Fully TIG welded frame and suspension components by yours truly.
Modding is one thing... designing from the ground up is another!
You think I should claim my 5?
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
Has thanked: 1609 times
Been thanked: 4065 times
As long as the e-brake works, you can claim a 5 for that.
:D :D :D :D :D
Couldn't you get one Volvo thing on that?
I love the Locost 7 moniker - well done!!
Botbasher
Post by Botbasher »
abscate wrote:As long as the e-brake works, you can claim a 5 for that.
Actually it will have an e-brake. Toyota handle and Wilwood cylinder with it's own reservoir. I gave up on trying to figure out how to route cables when I had to swap L-R on the rear uprights. I was looking at some nasty bends or bellcranks... NOPE!!!
Sorry about the lack of Volvo parts. There were not very many good donors in the WA yards!! So do I still get my 5?
I used a VW as that was 90% of all my experience is on and I wanted something unique (How many RWD VWs do you know of? :D )so I kept it comfortable. The VW/Toyota conversion is very common in Toyota 4WD trucks using VW diesels. So since all the VW blocks are the same.... I cheated a bit!
I'm already planning my next one which will be a mid-engine vehicle. I was going to design a BEC (Bike Engine Car), but after prowling around under the Volvo for a couple of days now and seeing how they package everything, I have changed my mind and will be clipping the front of a Volvo donor and making a Mid-Engine monster out of it. The 2.5 w auto trans is actually a pretty small package what you start eliminating things (power steering, AC...). It'll be a great donor.
Didn't mean to drag this off topic. If you want to see the whole timeline of the build, check out HERE for the entire thing! I'm Botbasher there too!
Cheers!
KS
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
By the scale I get a 4. I'm doing the top-end on my 3rd motor for the year right now (fixer uppers for my kids, or to pay for parts for the Volvos.) I have done a couple full engines, years ago. I still manage to find the hard way to do things, or sometimes re-do them! That is why I value these fora.
Current Volvos:
FLXC90
Post by FLXC90 »
Botbasher, as you have DIYed it, you are obviously a 5 as a tech. Fabricator, Designer, and tuner are all 5+ skills.
Current Volvos:
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
Do I have to subtract for msitakes?
No. An expert is one who has made all the mistakes..and learned from them.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I gave myself a 3 although I can give advice on 4 &5. I stop at taking the engine apart- the reason is that I've seen mine ruined before by a supposedly good mechanic...I certainly know what not to do and can help walk someone through a top end rebuild but don't really want to do it myself.
