CVVT Hub Replacement (How to DIY) - P2
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » How to Change CVVT Hub on P2 Volvos
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Re: CVVT Hub Replacement (How to DIY) - P2
Post by jonesg »
Offset is normal, probably due to the CVVT hub deflecting the cam sprocket.
Just set them horiz and use the locking tool.
Once you run the engine they'll go back to appearing offset again, no worries.
They all look like that.
I used a big screwdriver to lever the cam into proper position.
h20ham
Year and Model: 1998 xc
Post by h20ham »
Pelican is also helpful
https://www.pelicanparts.com/techarticl ... emoval.htm
Also, if torque to yield is 120 degrees, then that has streatched the head bolts to 120 degrees, so one would need to go further (like 125-130?) if reusing the $20 worth of bolts.
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
hans747
Year and Model: 1998 V90
Has thanked: 2 times
Been thanked: 2 times
Post by hans747 »
This document is immensely helpful, but I have a question about the blue hub on my 2004 xc70: Two weeks ago, I removed it to replace the cam seals. (yes, I used the locking tool and made my marks). Over that time, the hub leaked out a lot of oil. Now, when I go to reinstall it (center bolt snug, but not torqued), the forward and backward rotational stops are not at firm as before. The hub used to prevent me from twisting it past the stopping point. But now I can twist it much further. It makes a soft oily slurp/pop sound when I pass the forward limit.
I feel like all the oil drainage changed something. is there a way to refill the hub before reinstallation? Or will this come back to life when i run the engine and the hub pressurizes again?
I bought a used hub as a backup, and it acts the same way.
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Thank you for posting this. I'm doing this job on a project engine right now and this PDF has been very helpful.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Upstater
Year and Model: 2004 S60 2.5T
Post by Upstater »
Thanks and the info y'all posted is so generous and helpful
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Post by cn90 »
I also posted a very detailed DIY for my 2007 S60 in this forum...
