1998 s70 reverse jump polarity troubleshooting. Bad relays Topic is solved
Derbyrunner
- Year and Model: 1998 S70
I took out all the bigger fuses 50 amp and 60 amp. With key turned to on position the #6 60amp fuse labeled power to fuse box and aliment. Bootier fusib is sending the power to #10 15amp ignition fuse.
Derbyrunner
BEJinFbk wrote:That's the fuse that actually feeds the ignition switch itself.
From there it branches out to several things, including accessory
overload relays 105 and 106.
One way to deal with this is take a picture of the fuse box,
pull all of the other fuses and start putting them back one at
a time with the key on. Long way around, but it's a start.
This may help:
UPDATE the beast is up and going again. The short was in the 106 relay and main engine relay or at least one of the two as I changed both. Went through about 4 boxes of 15 amp fuses but that's cheaper than other big ticketed items. Thanks to everyone for input! I really appreciate it!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Those relays usually have a spike protection diode on the coil legs.
The reverse polarity probably melted it into a nice short to ground...
Glad you got it running!
Derbyrunner
The long way around proved to be a tedious job but worked out. I went through about 4 boxes of 15 amp fuses to narrow it down to main engine relay and relay #104 I think. It's running again and I'm very appreciative of all the input
- Has thanked: 2200 times
Well done for being persistent and seeing it through. Good input from all the guys who helped also!
- Been thanked: 4066 times
Changed thread title for search.
Thanks for sharing outcome as this might save someone a lot of fuses next time!
Tip for anyone reading this. If you're doing this kind of troubleshooting go and buy one of these circuit breakers and put it in place for testing to save a pile of fuses. https://www.amazon.com/Bussmann-BP-UCB- ... reaker+atcDerbyrunner wrote:The long way around proved to be a tedious job but worked out. I went through about 4 boxes of 15 amp fuses to narrow it down to main engine relay and relay #104 I think. It's running again and I'm very appreciative of all the input
2000 V70XC 160,000mi.
- Has thanked: 311 times
- Been thanked: 817 times
Somehow I missed this thread. First step (after replacing any blown fuses) is always to replace the three J relays, they are cheap and one or more of them will always be blown.
- Been thanked: 504 times
Jump the relay, if car runs, relay is bad.
Or get a few spare relays from junk yard for testing, make sure you label them which is which before swapping!
