1998 s70 reverse jump polarity troubleshooting. Bad relays Topic is solved
Derbyrunner
Year and Model: 1998 S70
Post by Derbyrunner »
Ok so I bought a running and driving 1998 S70 turbo and had to use a loaner battery to get it started and test drive. Car ran with no issues. Get it home and my teenage son who I bought car for hooked up new battery backwards. Now engine will not even turn over and the 15 amp fuse blows as soon as key is turned on. Need help badly
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
This has been reported before (reverse hookup), search forum for solutions, I think it is about checking a whole bunch of fuses.
Has thanked: 1609 times
Been thanked: 4065 times
This usually takes out the voltage regulator on the back of the alternator. Its actually good that it does this as this can get much more expensive than this.
Derbyrunner
abscate wrote:This usually takes out the voltage regulator on the back of the alternator. Its actually good that it does this as this can get much more expensive than this.
Is there a way to test voltage regulator?
Derbyrunner
Changed voltage regulator and car still blows ignition fuse.
Ugh. You will have to find the right wiring diagram on the inter webs and trace that fuse and all circuits on it to find the fault.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
It would be helpful if you identified the fuse slot #.
Derbyrunner
Fuse number 10
Post by cn90 »
Fuse #10 controls:
Ignition switch, Control modules - engine/automatic transmission 10 A
http://new.volvocars.com/ownersdocs/199 ... 70_102.htm
So it is down to:
1. A short in the wiring somewhere.
2. A short inside the ignition switch (which is extremely rare, almost unheard of).
3. A short inside the ECU, almost unheard of.
Please post a follow-up.
BEJinFbk
Post by BEJinFbk »
That's the fuse that actually feeds the ignition switch itself.
From there it branches out to several things, including accessory
overload relays 105 and 106.
One way to deal with this is take a picture of the fuse box,
pull all of the other fuses and start putting them back one at
a time with the key on. Long way around, but it's a start.
This may help:
98 S-V70 Fuse Locations and Legends.pdf
(678.65 KiB) Downloaded 241 times
