V70 AWD Transmission torque mount
Switchemlee
Year and Model: 1998 v70 xc awd
Post by Switchemlee »
Yes there is a difference between them. The holes for the rear bolts in the awd versions are different. Being the front hole facing the front end of the car is slightly lowered. Where as on fwd versions they are straight holes.
Switchemlee
Bought the part from skandix its a quarter inch shorter then the original awd one. Dont buy it. Its a rip off
Switchemlee
Did anyone eose buy the mount from skandix and have the same problem?
Has thanked: 2207 times
Been thanked: 1852 times
To try to help the debate, I pulled the lower (broken) torque mount from my 2000 V70 NA FWD today and compared it to one of the old AWD versions I have and took a few pictures to try to help others see the differences.
Some of the differences I'm not sure I can explain why and if they may make any difference, and most likely none at all.
View of bottom of torque mounts
Upper mount in picture is the FWD version. Only differences seen from this view is the shape of the front mounting section where the 2 studs are mounted. Not really sure if this would really make a difference. When viewed from the front they appear to be offset the same, so can't suggest why the difference in shapes unless there is something on the rear of the front cross member that determines the shape. In this case I think the forward portion would work on an AWD. The center portion between the bots is also the same. The front portions do have different Volvo part numbers which differentiates them.
Side view of torque mounts
Again FWD version is to the top of the picture. You can see the difference in the 2 bolt holes on the rear sections.
Close up of rear section of torque mounts
Close up of the differences in the rear portions
Top view of torque mounts
Viewed from above the mounts. RH one is only sagging as the rear mount has torn on the FWD version.
I cannot see and dimension differences between the 2 units or their respected bushes. There may be differences in the rubber stiffness but this I can't determine.
I looked at the replacement rear section that IPD does (ridiculous price $70 US - really!). I thing if the front bush on an AWD was good, this rear section could be used on a AWD, requiring some ovaling of the front hole to allow it to fit. From what I can see the FWD lower torque rod is used on P2's on both FWD and AWD versions. It may be possible to modify one of those by filing the front hole out. Not pretty, but could work.
Shame IPD don't sell the poly bush separately for the repair rear portion so you could swop it out yourself. Anyone want to take that on??
There are a couple of Swedish companies I have previously mentioned that sell the rear bushes separately, but again they only say for FWD.
Hope this helps those of you who are struggling with the lack of AWD parts.
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
Thank you Neil for taking the time to do this. My AWD seems to be holding on ok, but this is a great resource for this perplexing issue.
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Through I would update this. Both the Powerflex large and small bushings will work in the AWD mount.
2000 V70XC 160,000mi.
m96ag
Post by m96ag »
On a side note, does anyone know the size of the bolts that go into the transmission? I messed up the first 3 threads and need to grab a tap to clean them up
Thank you for taking the time to follow up on this. Can you find some time please to post a link to what/where you bought these parts (I know Powerflex but part numbers are always the best!!).
Many thanks.
BigRed
Year and Model: V70R 1998
Post by BigRed »
I went through this after mine had snapped and got whatever I could from junker and replaced the bushings.
Part numbers:
PFF88-611
PFF88-711
Sorry but don't know the thread than obviously metric.
If you have a bolt supplier locally they should be able to ID the thread for you.
Some time ago I bought a thread fixer the re-cuts the threads of bolt/studs and holes. I bought it at Princess Auto here in Canada, but I would be surprised if Harbor Frieght or the likes does not have one. It has saved my butt several times.
BigRed good to see you are still out there! How do you find the shift changes with the Powerflex bushes? Are they a bit rougher and do you get more vibrations through the steering? Thanks for the part numbers, I have a few lower torque rods that need new bushes to keep as spares or pass on!
