Swedish Car Parts Heater core Done.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
EBay core here, installed 12/14 I believe. From what I can tell, about 58,000 miles ago. Still rolling.
- Been thanked: 504 times
Ben,
Is your reservoir CAP in good shape?
I wonder if the CAP fails, then pressure builds up, and something has to give.
Just a theory.
Just a theory.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
+1 for the Spectra as well, bought from my local parts guy. Zero smell, looked well built.
I know Spectra is well known for making affordable aftermarket radiators, I had one in my Honda and it worked well.
What would concern me is how catastrophic that failure is, it is not like the OEM where it slowly starts to leak. I've never had any radiator fail like that.
It points to either quality problem with the material, or thickness of the plastic OR worst yet, the design selection of the material and wall thickness.
@CN90 if his cap failed, it would reduce the pressure in the system. The cap is designed to vent when the pressure exceeds a certain amount but old caps get leaky at all running scenarios.
@BEN850: make sure you send the failed part back, that is the only way the supplier can do an investigation.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Ben850
- Been thanked: 7 times
I went to their ebay site and the have a notation that they are now using a Black polymer for the tanks, claiming better rigidity.
If I find my receipt I will send it back.
They must have realized the issue.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
A cap can fail in 2 ways:mecheng wrote:...@CN90 if his cap failed, it would reduce the pressure in the system. The cap is designed to vent when the pressure exceeds a certain amount but old caps get leaky at all running scenarios.
1. The pressure relief valve is leaky, so the system is not pressurized at all.
2. The pressure relief valve fails "shut", no air is allowed to escape. In that situation, the system pressure is very high after a run.
Sometimes, in certain cars, the radiator hoses look like a snake that just eats a prey.
I was trying to get to #2 for Ben, if pressure is too high, things break at the weakest point.
Ben850
It would be sad if the weakest point was a two year old Heater core.
Although I had replaced all the other hoses in the system.
But still...
But still...
polskamafia mjl
- Has thanked: 19 times
OR this is an outlier and doesn't indicate anything about the quality of material or the design.mecheng wrote:
Ben850
As I had mentioned, they have changed the material for a quality reason as stated in their ebay ad, likely for a reason. They say it is black now.
I plan on replacing the cap as well either way.
Ben,
If and whenever you replace the cap, could you test it and post a follow-up?
The cap should release air at 15 psi or so (I need to verify this).
If not, then I wonder at what psi it will release air...
Inquiring mind wants to know...
- 1152 Views
- 12 Replies
- 7891 Views
Last post by crlande
- 11 Replies
- 3118 Views
Last post by foggydogg
- 56 Replies
- 18001 Views
Last post by BEJinFbk
- 1124 Views
Last post by theWIFES_S70
