94 850 Keep losing all electricity
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
I lose the radio first then everything- even the hazard lights- it usually comes back in a couple of seconds- I tried it with the six month old battery out of my wifes car and no difference- I will make up some new cables after I get the steering rack into the wife's v70
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Was the ignition switch new or a JY replacement?
Are you monitoring voltage while driving?
Maybe a dying accessory overload relay?
( 105 and/or 106 ? )
I'm just trying to figure out if your system is losing
power gradually or dropping out all at once.
And before you start replacing cables,
run some voltage drop tests.
- BEJinFbk
I missed the hazard lights...
That means constant power is dropping out.
I agree with checking all main cables, but again,
start with some metering before you begin tearing
things down. It may be an easier, cheaper fix.
And keeping an eye on your voltage levels is never
a bad idea when your having electrical problems.
You can tie in a DMM through the accessory connector
or just pick it up at the cig lighter with a plug.
These things are kinda handy, too:
http://www.ebay.com/itm/LED-Display-Cig ... Swc0FUnWHd
All shapes and sizes!
http://www.ebay.com/itm/4in1-3-1A-Dual- ... SwFMZWru~a
- 1492 Views
Last post by jvl
- 1733 Views
Last post by jimmy57
- 2193 Views
Last post by Sommerfeldt
- 12 Replies
- 3387 Views
Last post by Jaguar xjs
- 1647 Views
Last post by Rbaratt
