2000 s70 GLT accessory circuit losing power
rdupont714
Year and Model: 2000 volvo s70 GLT
Post by rdupont714 »
The blower motor, radio, windows, sunroof, SRS system, locks are not working. I replaced the ignition switch but nothing was fixed. I have checked all fuses. Is there anything else that I should check? Any help is much appreciated.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Next step - Ignition overload relay 105 ( AKA 2/30 ).
Screen Shot 2014-11-24 at 7.57.46 PM.png (84.45 KiB) Viewed 618 times
You may have sticky relay contacts. You can temporarily
swap 105 with relay 106 to see if that solves your problem.
rdupont714
That did not work. Any other suggestions??
Has thanked: 2203 times
Been thanked: 1852 times
Have you checked the B+ cable in the main fuse box? This is a real problem on 99/00 V and S 70's. Open the top of the fuse box in-front of the brake booster in the engine compartment and look down at the cable at the front RH corner (LH when viewed from front of engine compartment). There is a nut holding it in place. If it is copper/brass colored all is probably well. If it is dull and or black it is close to shorting out and can start a fire. I was lucky as I caught it before any harm was done, but when I removed the cable from the fuse box it was badly burnt and the plastic coating was melted. It could easily have shorted out.
Rbaratt
Year and Model: 850,S70,C70
Post by Rbaratt »
See if you have power at pin 1 of the overload relay socket. If not check fuse 11A/2 and for continuity between fuse 11A/2 and pin 1.
windows.docx
(318.25 KiB) Downloaded 195 times
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
Rbaratt
Post by Rbaratt »
Also if I am reading the schematic correctly (and I may not be!) I think you should have power to pin 2 when the key is in position 2. When pin 2 is powered it activates the overload relay which allows power to pass from pin 1 to pins 5 and 3. The Y-VO (I think that means yellow violet) wire to pin 2 comes from the ignition switch (pin 6?)...I know you replaced the ignition switch, check the connections if you don't have power to pin 2.
Rbaratt
Post by Rbaratt »
Radio Circuit
