Oscillating drone from engine at idle
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
VVT hub and solenoid on each camshaft on this engine, so 2 in total. Soleniods are hidden under plastic cover. You can unplug it when engine is idling. Make sense to disconnect only one at a time to triage which side is at failure.
keaunym
- Year and Model: 2009 Volvo S60 2.5T
I was hoping to lay that mystery to rest but disconnecting each solenoid separately during idle did not make the sound go away. Here's a video that might help explain the sound better:
What do you suggest next?
vtl
Actually, check also the right engine mount. It sits behind right wheel. If its rubber is separated, engine will touch subframe. Do you feel excessive vibration on the chassis?
keaunym
Would the A/C being on our off have any affect? I've tested this and it doesn't. I'm not sure where I'd see the clutch engage.vtl wrote:On the video it's sounds like a failing A/C clutch bearing. Do you see the clutch engaging when you hear that sound?
keaunym
Vibration doesn't seem excessive but I'll check for this mount tomorrow.vtl wrote:Actually, check also the right engine mount. It sits behind right wheel. If its rubber is separated, engine will touch subframe. Do you feel excessive vibration on the chassis?
vtl
Look at the A/C, its pulley start spinning when the clutch is engaged.keaunym wrote:Would the A/C being on our off have any affect? I've tested this and it doesn't. I'm not sure where I'd see the clutch engage.
keaunym
I'll check but I read if there are problems with the clutch, the A/C wouldn't blow cold air properly. It works fine.vtl wrote:Look at the A/C, its pulley start spinning when the clutch is engaged.keaunym wrote:Would the A/C being on our off have any affect? I've tested this and it doesn't. I'm not sure where I'd see the clutch engage.
vtl
I wrote "bearing". Your noise cycling is very similar to A/C cycling, noise is a typical failing bearing noise.keaunym wrote:I'll check but I read if there are problems with the clutch, the A/C wouldn't blow cold air properly. It works fine.
- 17 Replies
- 3820 Views
- 673 Views
Last post by whichcraft
- 725 Views
Last post by sanfelice
- 477 Views
Last post by jonesg
- 1579 Views
Last post by Sveedy
