That may be ... Apologies, I am in over my head trying to address AWD (and failed to read the thread!). Worth it to try a PM to Neil, he is user Scot850.Eglacias wrote: 11 Oct 2019, 00:49 Thanks for the reply, this particular thread mentions that situation I am in: the upper seat is built into the frame of the car on my 1997 850 awd low pressure turbo b 5254 t station wagon. Regular shocks it seems would simply have nothing to sit against. However, I do see a part number for that shock 9461631 that looks like it has the same upper diameter as the nivomats?
Failed Rear Suspension Replacement Attempt
- Has thanked: 311 times
- Been thanked: 817 times
Definitely not off-topic, considering those brake lines may get accidentally stressed when attempting to change the springs, you never know when we inadvertently make a mistake , and one must be very careful and inspect them before we reassemble right?
- Has thanked: 2200 times
I did not address jreed's point on the brake hose being worn. As part of the overall rebuild of the rear end of the car I replaced all the brake lines and flexi's (while you are in there). I replaced the hard line from one side to the other that is hidden by the fuel tank.
Interesting the same question came up here on how the replacement kit works. I know at one point Volvo actually sold a kit. I recall a friend using a kit he found by chance to replace the rear shocks on his 98 V70 AWD.
So the same question on how the top seats work as they loo different to the Nivomat version.
- 2318 Views
Last post by osmium
- 676 Views
Last post by rocket2247
- 1638 Views
Last post by mika
- 11 Replies
- 4371 Views
Last post by Faheyk1981
- 665 Views
Last post by pavlick
