I've had the 850 for almost 6 years and put about 72k mile on it.
Recently, I got a check engine light and read a P0141 code. Erased it and it's come back. Since I've owned the car, I haven't had any of the O2 sensors replaced.
Before buying the replacement Bosch sensor, I decided to make sure I could get the bolts off the plate below the O2 sensor. (Car's been in New England for its entire life, so bolt are sometimes tough to get off.) So I PB blasted them and waited a while. When I came back to try an loosen them, two turned pretty easy but never come out. They just keep spinning in place. Are what's holding the thread something like a PEM nut and is just turning?
-os
1996 850 GLT O2 Sensor Replacement Attempt
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- osman
- Year and Model: 2002 c70 hardtop
The heat shield? Im confused. You shouldnt need to remove it, O2 codes are usually a vacuum leak or lean/rich condition.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
osman wrote:The heat shield? Im confused. You shouldnt need to remove it, O2 codes are usually a vacuum leak or lean/rich condition.
Thanks for the reply.
I thought the P0141 code meant the rear O2 sensor was bad.
But, your reply reminded me that about a year ago I got a code (don't recall what) that wound up being the elbow in the intake manifold. I replaced the vacuum tubing and rerouted it. Turns out that the end that connected to the flame trap assembly had slipped off.
Put it back on. Will see if the code returns.
Thanks for your help. Won't have to deal with those bolts right now.
2021 Honda Pilot
2021 Honda Pilot
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes...the rear one.osmium wrote:...I thought the P0141 code meant the rear O2 sensor was bad...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
So if you have or can get an ohm meter measure sensor heater resistance at the connector. If you read some low resistane there then sensor is good.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Got the vacuum hose back on.draser wrote:So if you have or can get an ohm meter measure sensor heater resistance at the connector. If you read some low resistane there then sensor is good.
Check engine light came back on couple days later. - Found two codes:P0141 and P0136.
I take it these point to the rear sensor.
2021 Honda Pilot
2021 Honda Pilot
- 12 Replies
- 8382 Views
- 660 Views
Last post by rocket2247
- 1616 Views
Last post by mika
- 11 Replies
- 4344 Views
Last post by Faheyk1981
- 660 Views
Last post by pavlick
