97 850 trans - Swap from slushbox [auto] to exciting manual Topic is solved
This topic is in the MVS Volvo Repair Database » More Manual Transmission Swap Tips & Tricks
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Re: 97 850 trans - Swap from slushbox [auto] to exciting manual
Post by polskamafia mjl »
Your options are M56L or M56H. Have you carefully read the available threads?
beigg
Year and Model: 850 97
Post by beigg »
Would I run into any major issues using a 01' volvo v70 manual trans for use in the auto to manual swap regarding the 850 Wagon?
How I am understanding it is, I'd use the 01 manual trans. Then use the 93-97 SM Flywheel and clutch/pp/tob/hydraulics parts. It would be interchangeable to use the shifting cables, shifter arm assembly lever, brake clutch pedal assembly.
I can choose to swap the console bezel or modify it, which ever is suitable to my needs.
Is the above inaccurate information?
ugh smh 850 Turbo fridge
beigg
Post by beigg »
Any personal experience someone can apply?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
beigg wrote:Would I run into any major issues using a 01' volvo V70 manual trans for use in the auto to manual swap regarding the 850 Wagon?
If you want to use the 01 trans.
93-97 single mass flywheel, clutch disc, pressure plate, throw out bearing, and pedals with switches.
01 transmission and hydraulics part.
01 shifter with cables. or Any M56h shifter or cables, makes no difference.
85 GLH, 367 whp
00 Insight, 72 mpg
beigg
Post by beigg »
Good looking out! Those 01 hydraulic items will be corrected upon scavenging.
beigg
Post by beigg »
geeze the 01 hyd. parts are pretty pricy. Might be staying all pre 97 after all. lol
tryingbe
Has thanked: 1 time
Post by tryingbe »
beigg wrote:geeze the 01 hyd. parts are pretty pricy. Might be staying all pre 97 after all. lol
Not with the 01 transmission, you're not.
85 GLH, 367 whp
00 Insight, 72 mpg
beigg
Post by beigg »
Pre 97 all.
