I agree with whatever you say JRL. It just doesn't match up with literally hundreds of threads regarding what the B4 servo was able to achieve in the field. Engineer or not he may not be a transmission engineer or had anything to do with the design of the AW55/50 or AW55/51 series transmissions.
The B4 servo's function is to brake the 3rd gear drum. Transitions to and from this gear (adjacent ratios) would naturally be affected by its timing so to me and to many others here that makes a whole lot more sense.
A different issue with the B4 servo piston
precopster
- Year and Model: Lots
- Been thanked: 128 times
- Been thanked: 4068 times
Mike - double check your fuses - the B4 servo power shares a fuse with the third seat heater - a lot of people miss that one.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Senior tech in #1 New England Volvo dealership told me several times the front camber can not be adjusted on P2...
We debated good half an hour, he admitted it still has 1 degree of slack in bolts, but that's not what it called adjustment. Sigh...
Volvo says B4 may cause to-gear-3 and from-gear-3 problems: http://www.volvoxc.com/0/resources/how- ... -cover.pdf
I'm going to replace it too on my 2005 XC70, plus I'm switching back to OE ATF as since I moved to Amsoil/Mobil/Idemitsu/Valvoline/Aisin ATF 4 years ago it never worked really well. My diagnosis points to a low torque transfer in converter, Volvo might have more friction additives in its branded ATF.
12 litres of Volvo ATF is still cheaper than valve body replacement, which I'm almost sure is fine.
greffel
- Year and Model: 2003 S60
- Has thanked: 11 times
- Been thanked: 8 times
So on my S60 2.5T (my2003) i have 3-4 upshift flare / slip. Should I look into the B4 serve cover or just first try the oil flush?
Polestar 2 - All electric daily driver
S60 2.5T AWD with a little bit more power
- 992 Views
Last post by Jlewis2005
- 1110 Views
Last post by dux02v70
- 670 Views
Last post by skloon
- 1727 Views
- 949 Views
Last post by oragex
