12.2 volts is a deeply discharged battery, down to its last 20% of charge.
Can you put it on a charger for a day?
In the fine country ofCanada , batteries over 5 years old are at end of life.
Can I ignore these CEL codes - EDM - faulty voltage and others Topic is solved
Thenextman
- Year and Model: 2004 Volvo XC70
I could do this - borrowed an ancient car charger from a colleague. He says it works. Think it's worth a go?
Do I disconnect the battery to do this? What setting would you put it on - 12V 2 A or 12 V 10 A?
Thanks abscate,
Thanks abscate,
I'd disconnect the battery (leave in car if you want to not lift it out) and cycle it from 10a & 2a setting every hour for eight hours keeping an eye on it for excessive heat. It should not be cooking hot and a pronounced sulfur smell (rotten eggs) shouldn't emit during this process.
ugh smh 850 Turbo fridge
Thenextman
Thanks for all the tips guys.
I pulled the battery and charged it for about 7 hours today, cycling between 2 and 10 amps as @beigg suggests.
Put battery back in. Alarm sounded for about 3 minutes despite locking and unlocking doors with FOB but checked itself after a little time with the engine on.
Battery was reading ~ 12.5 v. Drove 25 km, reading 12.4v. Drove another 25 with radio loud and heat on high - 12.3v (may have had cabin lights on for these tests) Drove 2 minutes home - 12.55v with only trunk cab light on- 14.4v with car running.
AND Check engine light gone right when I replaced the battery.
Don't want to say I'm out of the woods yet, but 55 clicks with no CEL yet. Fingers crossed!
Thanks for your help so far guys.
Thenextman
75 km and no CEL - going to say this is ok for now. Thanks all.
Paul
Paul
- 15 Replies
- 2917 Views
Last post by 1ezliving4ume
- 6043 Views
Last post by misha
- 601 Views
Last post by wizechatmgr
- 3098 Views
Last post by oragex
- 269 Views
Last post by instarx
