Second time in 1 year spark plugs fouled up.
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 2004 S80 T6 did not have platinum plugs from the factory and it has 2 turbos. I was shown the plugs when removed by Osteen Volvo Service. The plug had a standard looking electrode like the old Buick plugs looked like. The Volvo plugs looked the same the second changing. Also my 2004 has a change mileage of 60K not 100K like platinum plugs. Why would Volvo be changing long life plugs early? I think you have been given misinformation from your aftermarket parts store. Your owners manual will give you the correct part number from the factory, try to cross reference that number to verify the correct plug type. It seems to me a name like iridium was used, not copper, not platinum.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- June
The correct Volvo part number is in your owners manual. I have seen all removed plugs from all Volvo cars I have owned but the 850 which locked up less than a year old and the S90 which was a total at three weeks old. None had platinum plugs and the V70 GT had the high pressure turbo. Here is a picture of the plug number for 2004 S80 2.9 and T6 from my manual. Look in yours and then cross reference the number rather than trust a non Volvo retailer. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I've been using NGK single electrode copper cores (NOT the ones with the little needle point center electrode) in both our our 2.5 turbo and 2.4 NA. About $2.00 a pop, so of course the parts houses don't want to sell them - I always have to order them. So far WAY OVER 50,000 miles on each set without skipping a beat.
At $10 a set thats a man after my heart - can you give the part number..and of course please buy them through the MVS Amazon link above...chrism wrote: 30 Mar 2017, 14:16 I've been using NGK single electrode copper cores (NOT the ones with the little needle point center electrode) in both our our 2.5 turbo and 2.4 NA. About $2.00 a pop, so of course the parts houses don't want to sell them - I always have to order them. So far WAY OVER 50,000 miles on each set without skipping a beat.
https://www.amazon.com/?tag=matthewsvolvo5-20
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
What factory retailer? My information is from the FSM like I originally stated. The FSM stands for factory service manual and platinum plugs electrodes don't really look much different than copper. I think your talking about Splitfire spark plugs or plugs that have multiple ground electrodes. Your owners manual isn't specifically for the S80 T6 model, it also applies to the N/A models. I'm pretty sure the S80 T6 is a 2.9L V6 engine and the factory Volvo plugs are platinum. The non-turbo Volvo's don't use platinum plugs and the Volvo plugs are Bosch plugs. This is the information that I'm getting from the FSM, this is why I started this thread. Copper conducts electricity better than platinum and is usually better in high performance vehicles but erodes faster. Check out this thread "spark plugs: copper vs iridium vs platinum ff#32".June wrote: 30 Mar 2017, 14:03 The correct Volvo part number is in your owners manual. I have seen all removed plugs from all Volvo cars I have owned but the 850 which locked up less than a year old and the S90 which was a total at three weeks old. None had platinum plugs and the V70 GT had the high pressure turbo. Here is a picture of the plug number for 2004 S80 2.9 and T6 from my manual. Look in yours and then cross reference the number rather than trust a non Volvo retailer. June
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- June
Just to satisfy my own curiosity I called my Volvo dealer and asked what type of plug ie platinum, copper, etc original equipment plugs are. I was told Volvo does not use platinum plugs in the modular engines but they are basically copper plugs branded by Volvo for Volvo Service replacement. In this car I have seen two sets, the factory that came out and the first service replacement set. I always ask to see the old plugs to see the color and condition which I was taught tells if a cylinder is not right. Both sets of platinum plugs I have seen are clearly different looking at the electrode than a standard plug. Once in dad's Buick and a set out of my sister's 2007 Chevrolet Impala when it was 100K old. If you really want to know call your local Volvo dealer parts department, that is who I was referring to in my previous post because your dealership is Volvo's retailer. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
chrism
Abscate, I believe those NGK copper cores are BPR6ES. I'm not near my pile of car parts receipts at the moment.
http://www.rockauto.com/en/partsearch/? ... num=BPR6ES
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
Right. The last plugs I put in were Bosch Platinum (according to the packaging) and they had various codes on the packaging and on the plug itself. On the packaging, they were 18-2988-8 and 6730. Stamped on the plug itself is FR7DPP30T.shiloh51933 wrote: 30 Mar 2017, 08:16The Bosch FR7DPP double platinum plugs are single electrode, the "double" platinum doesn't stand for double electrode.goldxc70 wrote: 29 Mar 2017, 19:23 Once, I picked Bosch plugs with platinum double electrodes as the "best" option (according to the parts store guy's computer) for my 2004 and it ran really badly. I pulled them immediately and replaced them with Volvo plugs. Had no problems with those.
chrism
I need to make a correction to that NGK p/n. I looked through my old receipts and found that on both our turbo and NA cars I used BKR6ES, not BPR6ES. So far they've been in the cars for 84,000 and 75,000 miles respectively. (I was shocked.) I don't know if there is any significant difference between "P" and "K" - same heat range. The chain store cataloging says "K" is the correct one.
- shiloh51933
2004 Volvo XC70 Owners Manual
They no longer make that Champion Spark Plug but it was a double platinum plugs and now Bosch makes the factory plug.
- 1087 Views
Last post by drjackmd
- 3306 Views
Last post by ndphotonl
- 1840 Views
Last post by vtl
- 2801 Views
Last post by TheMrFailz
- 2066 Views
Last post by oragex
