YeS, pull the turbo and vacuum it out. Inspect for damage
They are easily rebuilt cheaply, and moreover every pick and pull grifter yanks the turbos out of junk cars thinking they harvested something of value because it’s a turbo.
You can buy them for $100-150, dont pay more.
Harry’s sells them for $60
Spark plug exploded in engine
- Been thanked: 4069 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sad to see this. A good reason to permanently remove the black plastic cover from the engine top, this way we can see for any oil leak on the engine cover and prevent timely from leaking it into the spark plug holes. By the way, the ignition coils do not seal "water tight" these holes, despite having a rubber base. I once had the bright idea to spray some water over the top of the engine, and sure enough 3 of the 5 spark plug holes got filled with water (and I lost a coil by the same)
I'm gonna pull the turbo tonight,, I'll update with details, thanks for the info!!abscate wrote: 16 Aug 2019, 04:34 YeS, pull the turbo and vacuum it out. Inspect for damage
Volvo,, I don't think it would have happened, if my coil harness wasnt in such bad shape.cn90 wrote: 16 Aug 2019, 07:35 For broken insulator, what was the brand of spark plugs?
I use only Volvo, Bosch or NGK.
- 3074 Views
Last post by Roger_850T
- 1450 Views
- 2478 Views
Last post by matthew1
- 3902 Views
- 1951 Views
