The dealer has it right now and they are investigating. They said they have never seen it happen. PCV system tested fine. It's been loose and I kept pushing it down which probably made it worse. I'll find out in a few days what they find.s10lowrider1994 wrote: 04 May 2017, 19:58 I was kidding, hence the part about the pressure going somewhere else. Installing a new cap isn't going to fix what caused it to blow out. Did the dealer do a leakdown test or just put a glove over the dipstick and assume things were fine? You're not going to find anyone that has seen one of those caps blow out all by itself which is why people keeping telling you that the problem is elsewhere. Things like mileage, modifcations, etc. can all play a part in what might have happened, but you didn't mention any of those. You just assumed the cap fell out and the car was designed poorly but these engines don't randomly pressurize and destroy unless something isn't right. It sounds to me like you bought someone else's problem and nobody who's touched it so far has the slightest clue what they're looking at.
Frustration level 10! Round cap blown off top of engine Topic is solved
2001 S80 T6 Moondust sent to auction for scrap
s10lowrider1994
- Year and Model: 2000 v70
- Been thanked: 3 times
Hope they get it straightened out, I've never seen one dislodge all by itself. Maybe it was messed with previously and just wasn't in there very tight. If you get it back and they don't find anything other than the cap, keep an eye out for new oil leaks for a while just to be safe. Any sort of new seepage will indicate that there is excessive pressure and it's now finding another way out.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
If there were that much pressure in the crankcase from excessive wear and blowby to push that cap out, wouldn't that pressure also be pushing oil into the cylinder on the intake stroke (white smoke, probably a lot of it)? I would imagine it would take no less than 20-30 psi to push that out.s10lowrider1994 wrote: 04 May 2017, 20:36 keep an eye out for new oil leaks for a while just to be safe. Any sort of new seepage will indicate that there is excessive pressure and it's now finding another way out.
I'm thinking a either a PO messed with it or you just happened to catch one of those freakish one in a million things (machining error on the valve cover or a hairline flaw in that cap that weakened it's grip). Three likely dealers near Evanston you probably took the car are known to have competent service departments. If there is something seriously wrong with the engine I'm sure they'll find it.
I think someone did, it's always been loose and whenever I was under the hood I would tap it down with the end of a ratchet. My fauklt for not addressing it sooner but, it didn't seem out of place at the time. The front one hasn't budged.s10lowrider1994 wrote: 04 May 2017, 20:36 Hope they get it straightened out, I've never seen one dislodge all by itself. Maybe it was messed with previously and just wasn't in there very tight. If you get it back and they don't find anything other than the cap, keep an eye out for new oil leaks for a while just to be safe. Any sort of new seepage will indicate that there is excessive pressure and it's now finding another way out.
It's at Fields Volvo right now having some evap work done as well as a new cap.mrbrian200 wrote: 05 May 2017, 21:52If there were that much pressure in the crankcase from excessive wear and blowby to push that cap out, wouldn't that pressure also be pushing oil into the cylinder on the intake stroke (white smoke, probably a lot of it)? I would imagine it would take no less than 20-30 psi to push that out.s10lowrider1994 wrote: 04 May 2017, 20:36 keep an eye out for new oil leaks for a while just to be safe. Any sort of new seepage will indicate that there is excessive pressure and it's now finding another way out.
precopster
- Year and Model: Lots
- Been thanked: 128 times
My cap started leaking on my 2001 V70 T5 around the edges and dropping on the exhaust. Used something like JB Weld (2 part metal epoxy) and so far so good. Hitting it in the middle to expand it at the edges sounds like sound advice from jimmy57
My T5 blew the dipstick out a couple of times however PCV is good. It happened both times after a full acceleration burst. New fatter O rings on the dipstick seems to have fixed it for now.
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
I thought they had told you the PVC/Evap was fine? so it was building pressure after all?Legofan wrote: 06 May 2017, 18:43It's at Fields Volvo right now having some evap work done as well as a new cap.mrbrian200 wrote: 05 May 2017, 21:52If there were that much pressure in the crankcase from excessive wear and blowby to push that cap out, wouldn't that pressure also be pushing oil into the cylinder on the intake stroke (white smoke, probably a lot of it)? I would imagine it would take no less than 20-30 psi to push that out.s10lowrider1994 wrote: 04 May 2017, 20:36 keep an eye out for new oil leaks for a while just to be safe. Any sort of new seepage will indicate that there is excessive pressure and it's now finding another way out.
They did, evap(emissions) work is for the J hose at the charcoal canister in the back, it's cracked. As I understand it that is separate from the PCV system?ThommyKent wrote: 06 May 2017, 21:01 I thought they had told you the PVC/Evap was fine? so it was building pressure after all?
I haven't had any issues with the dipstick and at idle I do have negative pressure. This happened right after full acceleration. I wonder if there's not enough blow off for the turbos causing high crank pressure but, I don't think those are linked.precopster wrote: 06 May 2017, 19:42 My cap started leaking on my 2001 V70 T5 around the edges and dropping on the exhaust. Used something like JB Weld (2 part metal epoxy) and so far so good. Hitting it in the middle to expand it at the edges sounds like sound advice from jimmy57
- mrbrian200
Compressor bypass valve is all on the intake side, in front of the throttle plate. Unwanted spike in charge pressure (if the valve is stuck shut) doesn't get past the throttle plate. So, No.
- 37 Replies
- 6741 Views
Last post by erikv11
- 790 Views
- 12 Replies
- 7208 Views
Last post by RickHaleParker
- 1448 Views
Last post by surelyujest71
- 1316 Views
Last post by skloon
