98 V70 T5 - Starts and dies
neworleans
- Year and Model: 2007 S60R
Thanks again, I will try it today.
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
Had this exact same problem today. It was the fuel pump relay. See here: viewtopic.php?f=1&t=80457#p439298
People kept suggesting it could be the MAF, Throttle, vacuum leak, etc. but I knew it had to be a fuel issue.
Switchemlee
- Year and Model: 1998 v70 xc awd
Listen closely to hear the fuel pump on the rear passenger side when you turn your key to the second turn of the key in the ignition switch if you dont hear it when you go to that posistion most likely is the fuel pump relay.
Switchemlee
Also can check for fuel pressure at the bleeder at the end of the fuel rail after you try to start car to see if youre getting fuel
neworleans
Hey guys,
You guys nailed it. It was the fuel pump relay. Went to pull a part and picked one from a 850 for 3 bucks and it worked.
Thank you very much. You guys are great.
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Excellent news, glad you were able to repair it. I keep 3 spares in my S70 and have sold two to stranded owners of P80's when theirs went out.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- 4713 Views
Last post by oldvolvos
- 2804 Views
Last post by Skidplate
- 2392 Views
Last post by 93SCMax
- 962 Views
Last post by MoVolvos
- 827 Views
Last post by screwdriver
