Transmission fluid brands
PLEASE302
Year and Model: 2010 s80 t6
Post by PLEASE302 »
FYI. Just changed atf using several drain and fills with valvoline max life atf. I noticed slipping with this fluid and finally decided to flush with volvo atf and the slipping stopped almost immediately.
Apparently, max life may have too many friction modifiers and was not suitable for my 2010 volvo s80 t6 with 85k miles
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
PLEASE302 wrote: 10 Oct 2018, 16:10 FYI. Just changed atf using several drain and fills with valvoline max life atf. I noticed slipping with this fluid and finally decided to flush with volvo atf and the slipping stopped almost immediately.
The maxlife doesn't actually say it's a JWS3309 spec oil anywhere as far as I can see. Thus I'm not too surprised if it didn't work as well as the correct oil.
KurtL
Year and Model: V70R 2005
Been thanked: 5 times
Post by KurtL »
I use Aisin Type T-IV. I replaced the transmission in the 2001 2.4T with a used one at about 120,000 miles. It now has 200,000 miles. I drain and fill about 3.6 quarts every oil change at 5,000 miles to keep it fresh. It shifts great.
I bought a 2005 V70R last summer and have been doing drain and fills with the same fluid 4 times over the last couple of thousand miles. It was having hard shifts when I first bought it but seems to be shifting better. It the been taking 3 quarts each drain and fill.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Please note that EVERYONE refers to "MaxLife" in these threads.
The one I've used without hiccough in four of these (our) transmissions is the "MaxLife Dex/Merc LV".
The Dex/Merc LV is the one you want.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I use Aisin Warner OT4 for all 4 of our Cross County's, Aisin Warner is a large manufacturer of Automatic Transmissions. I believe Aisin Warner transmissions are used on many Volvo models. I also believe that Aisin Warner is the ATF in the Toyota Type IV bottles, regardless it has worked well for my Volvo's.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
FCP alleges in their description that Idemitsu is the supplier to Volvo and that the type TLS is the Volvo OE fluid. I will be using it this week.
