03 V70 Parking Brake - How much movement ( Answer: None) is OK? Topic is solved
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
Guys guys.... RFQ!!!
It stops just like a E-Brake should. It has no operational issues. Pull handle... Car doesn't roll.
What it does have is slop equilivent to the slop in an automatic trans before the pawl locks. Is this slop normal or is there something wrong? I'm used to E-Brakes that when applied, the car doesn't move more than the suspension allows. Mine has about 10 degrees worth of movement BEFORE hitting a stop. Clank ..... FWD..... Clank.... REV.... Clank..... FWD..... Clank.... you get the point hopefully.
If I don't need to tear it apart to correct an issue that isn't, then I see no reason to... I have better issues to deal with especially when the E-Brake is otherwise functional. If this is truly an issue I'll be happy to dig into it and see what's wrong. Not knowing how Volvo works their E-Brakes... I'm at the mercy of those that do!!
Cheers,
K "sloppy" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Something is moving, I would look at the round locating springs , could also be loose brake liner on the shoe. The liner can detach but remain in position whilst sliding back and forth as brake is applied and released. Or ignore it, the car will pass inspection. I don't use my brake from one yr to the next .
Has thanked: 1610 times
Been thanked: 4065 times
Something is fubar inside.
Botbasher
Post by Botbasher »
jonesg wrote: 04 Jun 2017, 19:02 Something is moving, I would look at the round locating springs , could also be loose brake liner on the shoe. The liner can detach but remain in position whilst sliding back and forth as brake is applied and released. Or ignore it, the car will pass inspection. I don't use my brake from one yr to the next .
The brake is never released.... It's applied.... I lift the car... I grab the rear wheel and I can rotate it about 10 degrees before it clanks to a stop and then I can do the same the other direction!
What are these inspections everyone keeps mentioning?? 8) Cali and WA never inspect cars.. just OBD. NC inspects, but it's more OBD and basic operational (wipers, windshield, tires and lights...). I have German and British friends that have visited and were amazed at the things we can do to our cars without getting into trouble.
Inspections... we don't do no stinkin inspections!!
K "lucky" S
Botbasher
Post by Botbasher »
abscate wrote: 04 Jun 2017, 20:48 Something is fubar inside.
OK... now that is my kind of comment!!! :lol: At least now I know it's not normal.
Now to figure out what's going on!! I want to try and find that adjuster that one guy used though. First car was a 1952 Ford... 4 drums... doesn't seem right to have drums without an adjuster!
Thanks!
K "fubar" S
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 04 Jun 2017, 03:58 MASS DOT is pretty rigorous on inspections. I think in MT, as long as you had a gun rack, it passed.
All they do is OBD-II scan and check that the fuel door is locked. In Czech Republic, for contrast, you fail if they see any sign of wear in control arm bushings. Inspection takes there about 2 hours, they lift the car in to the air and go all over it.
Botbasher
Post by Botbasher »
vtl wrote: 05 Jun 2017, 09:23
Yeah... MOT in Britain is like that too (20k garages with 50k techs.... Now that's how you stop unemployment!!). I was amazed at cars they'd send to the wreckers because it failed MOT and was just going to be easier to replace than repair. There really isn't much of a dependable used car market in GB. You can sell used cars, but there was a high incidence of it failing it's next MOT due to a cleverly disguised accident that only turned up from under the car!
I hear some other EU countries are like that too. Having lived through my time in Cali, I wish the states would do something similar. Watching cars literally disintegrate as they travel down the road from across the southern border... was always a scary time on the interstates!
I'm covered either way as I have my gun racked in the back under the floor board and the car is in great shape now!! :wink:
Cheers!
K "prepared" S
jonesg
Post by jonesg »
Botbasher wrote: 05 Jun 2017, 08:40 I lift the car...
OK now remove the wheel and pull the disk off.
jonesg
Post by jonesg »
Botbasher wrote: 05 Jun 2017, 08:40 The brake is never released.... It's applied.... I lift the car... I grab the rear wheel and I can rotate it about 10 degrees before it clanks to a stop and then I can do the same the other direction!
K "lucky" S
Thats confusing, if the front wheels are on the ground your engine is probably not running.
The hand brake is tested with wheels on the ground , running and in gear.
If it passes the test then ignore what its doing with wheels in the air.
Botbasher
Post by Botbasher »
jonesg wrote: 05 Jun 2017, 10:02
Oh, if only it were that quick!!!
I happen to find this while bleeding the brakes.... wheel was still on.... car was just barely off the ground to give my arms a little more room. I grabbed the wheel to move behind it and it rotated. I pulled my arm out quickly as I thought maybe I forgot to set the brake, but nope... it was applied hard. I investigated by rolling the airborne wheel back and forth and when the wheel hits the stop it isn't moving past that. It's like one of those playground steering wheels that you just knew you were strong enough to rotate past the stops if you could just get enough speed between the two points!
When I lower the car it always moves a bit and then stops after it hits this point. If I pull on the handle while the car is rolling, you hear a MASSIVE clank and then feel the drag apply.
My 98 is similar in action, so that's why I am wondering if I have an issue... or if this is just the norm?!?
Ciao!
K "unlucky in pairs?" S
