2002 V70 No Start saga
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Re: V70 No Start saga
Post by Roger_850T »
It looks like it was very loose, and they ran it, for a while. Then it started giving "Cam Sensor" error codes, and stopped running. Whoever worked on it rectified their mistake by torqueing it to such a high value, it took 200# on a 5' cheater bar to get it off. That might have worked if they had got it aligned properly, but they didn't.
I have a new gear on order, and I'll put it in and see how the compression is looking then. (Yes, I do the compression test with a full battery, plus a 50A "helper", plugs out, throttle wide open.) Previously I've got 95 psi on all of them, which sounds more like a "cam out of timing" than bent valves, I hope. I think I was very lucky that the gear wore badly, but the crankshaft itself seems to be relatively undamaged.
I put a video on youtube showing the gear and the play.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Has thanked: 1498 times
Been thanked: 3810 times
Great video Roger, nice and clear and good lighting.
That is a nasty play in the crank pulley, but I'm wondering how this gets loose?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
Someone made a mess of that, didn't use a crank lock tool, used original fastener, no torque wrench, maybe relied on a rattle gun,
the list could include more. I got away with doing all that on my non interference 740 and the bolt never came loose.
Did you take a look at the pistons?
Roger_850T
I put on the new crank pulley tonight, and I think I got really lucky. The compression has come up from 95 across the board to 175-182 on all 5 cylinders, and with all the cranking I did with the compression test, I did not get the "cam sensor" ECM code once. Hooray! With compression like that, I think I have no bent valves, and that all the dings in the top of the pistons were not hard enough hits to damage the valves. I'll work on getting it all back together, then see if it will start and run. :D
Roger
11 XC60 137k
05 XC90 V8 213k
jonesg
Post by jonesg »
Go out right now and buy a lottery ticket.
Roger_850T
It runs! Hooray!
Although I also figured out that the alternator appears to be dead. The red light stays on, and the DIM gives a message that the Electrical System Requires Service. And the voltage doesn't come up, the car runs off the battery and the voltage drops down towards 11V.
Chances are that either the PO or I managed to wreck the diodes with the "50A Start" battery charger. Ah well, now to fix that.
But it runs! Hooray!
11 XC60 137k
05 XC90 V8 213k
Nice, well done.
The ignition coils often get torched after a jump boost so keep a spare and watch for misfire codes , P030x
