94 850 Turbo running rich and idling high
Vazfx16
Year and Model: 1994 850 turbo
Been thanked: 2 times
Post by Vazfx16 »
The sensor is (if you are facing the car), left side, to the left of the intake manifold and to the right of the pullies . It is connected into the thermostat housing. In my situation, the plug's internal bullet connectors where not seating properly. The plastic plug with click into place as it should, but internally the bullet connectors were not making good contact. I pulled the bullet out a bit (with out damaging the thing wires), and plugged them into the female connector. Then I connected the plastic part of the connector. Everything was better instantly.
skloon wrote: 30 Jun 2017, 12:16 is this the sensor low on the front of the block ?
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
okay will go steal on off one of my wifes cars
Vazfx16
Post by Vazfx16 »
skloon wrote: 30 Jun 2017, 12:54 okay will go steal on off one of my wifes cars
Just remember, it may not be the actual sensor...it could just be the plug. Check the plug carefully for corrosion and a proper connection of the metal parts.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You can't without draining coolant a bit.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Vazfx16
Post by Vazfx16 »
misha wrote: 30 Jun 2017, 13:19
Correct. Drain about a liter or so out. Just enough so that there is no coolant in the upper radiator hose. YOu will have to then move that hose out of the way. Undoing it from the thermos housing
Has thanked: 1610 times
Been thanked: 4065 times
Park up hill on a curb, then point the hose to the sky as soon as it's off? That should work rather than fussing with coolant.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
misha wrote: 30 Jun 2017, 04:23 Yes....IF it is dead and you leave it connected.It gives false reading,almost like bad Maf.
If you disconnect it's connector...all you get is check engine light.
Trust me,i've tried it numerous of times on Volvos and other cars with success.
So what you're saying, really, is that the rear o2 sensor doesn't actually do anything at all, since you can simply disconnect it, and all that happens is a CEL, and that it's only a source of potential problems? That seems very, VERY dubious to me.
- S
[Sold] '97 S70 T5
misha
Post by misha »
What would you say on this...my friend drives a car for two years just on Rear o2 sensor which is in it's rear position,connected to a Front o2 connector and cat removed?!Rear o2 plug is disconnected.
Besides check engine light and code for a rear 02 sensor,there is no other codes.
If you have doubts try it,but you would need to remove cat.Otherwise your engine would running lean.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt wrote: 05 Jul 2017, 00:29
- S
It does, but is correct.
The rear sensor just checks the exhaust fro oxygen content after the catalytic converter and reports to the ECU AIF the cat is doing a good job. The ECU does nothing with this information, it only uses the front O2 sensor to monitor and adjust the fuel deliverd ( it uses other things too) If the rear O2 sensor reports out of range, the ECU sets the Low cat efficiency CEL
Sommerfeldt
abscate wrote: 05 Jul 2017, 05:07 It does, but is correct.
This makes little sense to me - if this was accurate, then a dead, dying or faulty rear 02 shouldn't have any effect at all (besides a CEL). It certainly should not have made a great big rich condition when mine went out. There's a flaw in your arguments, gentlemen.
- S
[Sold] '97 S70 T5
