THe video , that deep popping sound, my guess is oil pan combustion.
Along with smoke from dipstick etc.
My concern would be for the rear main oil seal getting blown out.
I'd drive with the dipstick loose to relieve pressure in the pan til you get to that PCV cleanup.
2001 V70 2.4T inconsistent startup issues
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
We've actually been driving with the dipstick removed for a while just for that reason.jonesg wrote: 01 Jul 2017, 07:30 THe video , that deep popping sound, my guess is oil pan combustion.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- prwood
If I had routed the serpentine belt incorrectly, could it have caused the types of issues I described in this thread?
Cars I've owned:
- prwood
Well, I don't know for sure, but I have a feeling that I routed the accessory belt incorrectly when I had taken it off in the process of doing the coolant diagnosis. Then on Saturday I did the timing belt, and had to take off the accessory belt again. Unfortunately at that point I didn't make a record of how the serpentine belt was attached, so I don't know how it *was* routed. When putting it back on, I double checked the routing with a diagram I had used in the past, and while looking at it I had a feeling that I may have previously misread the diagram.
In any case I triple checked this time when putting it back on. Ever since, everything has been working great. No startup issues, surging, or A/C compressor issues whatsoever. My theory is that previous way I had routed this belt allowed the car to work somewhat, but some of the pulleys must have been spinning in the wrong direction and causing some of the components (especially the AC compressor) to freak out. It must have also been causing things to seize up occasionally which is why it would sometimes die immediately at startup. I suspect the computer also detected this and that this is why I was getting the 'engine system service required' message. Unfortunately, even after disconnecting the battery, that message has come back, so I suspect it's a sort of permanent mark that gets logged in the computer if it had detected an issue like this in the past, so that a Volvo repair shop will know that something was screwed up at one point. Hopefully I didn't permanently damage anything when the belt was misrouted, but I've been testing it pretty thoroughly since Saturday (various combinations of AC, no AC, periodic AC changes), and not a single problem.
Cars I've owned:
- Has thanked: 987 times
- Been thanked: 1075 times
I realize this is an old and dead topic, but I want to clear up misinformation about the box containing the ECM and TCM. On 2001 V70 T5 models (and perhaps the non turbos also), there is an air duct from the cabin air flow that blows air into the back side of the box. Air exits the front side of the box and another duct extends behind the fan shroud and is open. My assumption is this air flow is to cool the ECM and TCM in hot weather when the cabin is assumed to have air conditioning. If you have the cabin fan on high, you can feel the slight flow at the front of the box.
- Been thanked: 4064 times
Did this problem ever return?prwood wrote: 06 Jul 2017, 10:27 Well, I don't know for sure, but I have a feeling that I routed the accessory belt incorrectly when I had taken it off in the process of doing the coolant diagnosis. Then on Saturday I did the timing belt, and had to take off the accessory belt again. Unfortunately at that point I didn't make a record of how the serpentine belt was attached, so I don't know how it *was* routed. When putting it back on, I double checked the routing with a diagram I had used in the past, and while looking at it I had a feeling that I may have previously misread the diagram.
Starting in 1999, Volvo alternators have one way clutches so they will only output turning in the ccw direction facing the pulley. That will trigger the “engine service required light” too
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Wow
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
