After turning the car on there are several issues that I am experiencing.
Symptoms:
Cannot shift out of park
Turn signals don't work
Headlights/running lights do not turn on
Cruise control does not work
I'm stuck on this. Any help is appreciated.
Intermittent Electrical Issues on Startup Topic is solved
- dmg4
- Year and Model: 1993 245 Classic
- Has thanked: 1 time
Could we have a bit more information?
1. When there is an electrical fault, do all of the above lights and cruise control fail, or only some of the systems?
2. Does the electrical fault occur after you escape "Park" by depressing the Shift Interlock button, and only after that?
3. Does the electrical systems sometimes or usually work again if you turn the ignition switch off and then restart the car?
Frequently wrong, never in doubt.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
My first thought would be checking the multi-switch on the side of the steering column. My next thought would be checking the main headlight relay.
1988 Volvo 760 Turbo Wagon
The car is a 1996 960. The electrical faults happen only when the car is warm (warm weather >60F or after the car has been running and is then turned off)
1) All of the systems fail every time the fault occurs
2)When the fault occurs the headlights do not turn on, the ignition chime signal is silent and the turn signals do not work before I try to shift out of park. Once the shift lock override is depressed I can shift but all previous symptoms remain.
3) The faults rarely go away after restarting the car and only if the temperature is cool.
Do you think that the issue is possibly in the ignition switch given that the only way to shift out of park is to manually override the shift lock?
- 1265 Views
Last post by Salomons Driveway
- 1123 Views
Last post by firstv70volvo
- 17 Replies
- 3192 Views
Last post by darrylrobert
- 1132 Views
Last post by xHeart
- 11 Replies
- 5904 Views
Last post by oragex
