E-brake doesn't work...
This topic is in the MVS Volvo Repair Database » How To Replace Volvo E-Brake Pads
CarVolvo
Post by CarVolvo »
They say a picture is worth 1000 words... great write up...will help many!
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Thank you Lee for the detailed DIY. I have done many Parking Brakes in different cars before, but I have a question re hardware kit.
I want to replace the Parking Brake Shoes, and during that process want to change the hardware kit too.
From my research on different online vendors (FCP, eeuroparts etc.), they sell "Scan-Tech":
http://fcpeuro.com/products/volvo-parki ... 70-s70-v70
Normally I hate Scan-Tech but has anyone uses this hardware kit by Scan-Tech before?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It would be hard to screw up a brake hardware kit but if it can be screwed up I think Scan Tech could pull it off. In my case I just cleaned up and re-used the old stuff. I know that is a "non answer" answer but I have no real guidance based on experience.
Post by cn90 »
Thanks Lee,
I just looked at the link I posted above. The Volvo dealer sells these parts separately.
So they are below if people want to use Volvo OEM part (instead of Scan-Tech!). Search for qty needed.
1273836
9157979
3546028
schmidm90
Year and Model: 2000 V70 XC AWD
Post by schmidm90 »
I was trying to replace my parking brake the other day and had a few difficulties. I had the rotors machined and was going to replace the parking brake pads as well. I re-assembled everything and then the rotors would not fit with the hardware. I realized while replacing the shoes the cable were stuck as well. I just ordered new cable and plan to try and replace the pads again. If the cable were stuck could this be the reason why the new pads wouldn't fit?
Any help would be appreciated!
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
Post by Ozark Lee »
It very well could be the reason depending on what position the cable got stuck in.
If you can snap a picture of the actuator at the bottom of the parking brake assembly and post it back we can tell for sure.
schmidm90
Post by schmidm90 »
So the new pars I ordered were for a V70 not a V70XC.... Have to be more careful when I go through ebay again. I figured out the reason was the cables because once the cables were out I could fit the new pads in. The other question I had was it looks like the cable was clamped onto the mechanism to apply the parking brake. Is this possible? At the junkyard I saw how most cable slide into the mechanism, but mine doesnt have it. I will try to post a picture but is this just on the V70XC and how would I connect the new cable?
2000 V70XC - 199k
holler1
Post by holler1 »
The new cable should have a piece on the end that looks like the lower left piece on the picture. You can see where the old cable was cut or wore out. You need to drive out the pin that holds the cable end to the actuator, then connect the new cable end. The pin should slide out and back in fairly easily. When it's in position, it is held together by being inside the larger part of the actuator. After connecting the new cable, check to make sure the actuator parts move together easily. The part of the actuator that connects to the cable should move through the other part until about 1/2 inch of it is sticking out thru the other part.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
holler1
Post by holler1 »
cn90 wrote:Thank you Lee for the detailed DIY. I have done many Parking Brakes in different cars before, but I have a question re hardware kit.
I just replaced my ebrake shoes, and tried a set of Scan-Tech springs. In my opinion, the Scan-Tech springs are weaker than the originals. I stretched one beyond its elastic limit in just putting it on, and the spring ended up about 1/4 inch longer than it should have been. After that the spring wasn't strong enough to pull the shoes back into the proper position after pulling and releasing the ebrake. I went back to the original springs. Here's a picture showing the"stretch".
schmidm90
Post by schmidm90 »
So far taking mine out all my original springs are still good (knock on wood). I am going to get new cables tomorrow from the stealership and put it in with new pads. I have checked everywhere and almost all of the places I looked were around $50-$60 per cable except FCP Groton(who is out and wont get any for 3 weeks). I would like to finish it this weekend and it looks like going volvo is my only choice....Thanks for all the feedback guys! I will post some more pictures once I get it all back together!! Your replies are greatly appreciated!
2000 V70XC - 199k
