Is this the end? 98 S70 T5 knocking noise
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Re: Is this the end? 98 S70 T5 knocking noise
Post by mrbrian200 »
readallthebooks wrote: 17 Jul 2017, 22:38 sounds like lifters to me too. isnt that a really common issue on these cars?
He said he replaced the cylinder head about 20k miles ago.
When a lash adjuster fails on these can it vent enough oil to result in an oil pressure issue? OP mentioned it's taking longer for his oil light to go off when he starts it.
Cmblackburn I still think you should try replacing the sump O-rings. But for the sake of gathering information:
Where did the replacement head come from? Low mileage used or rebuilt? If rebuilt who/where?
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
The sump o-rings is such a common problem, and fits the perceived symptoms well including lifter noise ... If they haven't been replaced they are almost certainly at least part of the problem. E.g. you can hardly bother to speculate any other reason for the oil light at this point.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
I pulled the head off of a running '98 V70XC with 82k miles and had it resurfaced and new valve stem seals installed at my local NAPA, they did a great job with it. Engine ran perfectly in the car I yanked it from- was in the junkyard because the elderly owner died and it had no title.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
