Torque Specs for ball joint
Merde!!!
Can you pull one out and measure the shaft diameter - hopefully 10mm?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Yep those are the nuts and bolts I've done in my V70.Metallo wrote: 19 Jul 2017, 04:18 H
Those are the bolts and nut I refer to, to me, this is a ball joint attached to a knuckle, I do not see any clear reference to this in the VIDA table above, obviously I cannot find consistency in the terminology used in that table that leads me to conclude those are the bolts and nut they refer to.
I hope this clarifies what I am puzzled with.
Have fun!
Alex
Metallo
- Year and Model: XC 70 AWD 2.5 - 2006
- Has thanked: 7 times
- Been thanked: 6 times
You mean the thread diam. where the nut goes?abscate wrote: 19 Jul 2017, 09:45 Can you pull one out and measure the shaft diameter - hopefully 10mm?
Alex
Polar 940 Turbo SW - 1997
I meant the the diameter of the bolts holding the ball joint to the spindle but Im reading this better now
You have two different torques to consider
Two bolts that hold ball joint to spindle
Big nut that holds the ball joint to the steel/aluminum control arm.
Once you know what your control arms are made of, I think the VIDA table is clear what you need
Metallo
If the VIDA info was clear to me. I would have not been trying to get this information since yesterday.
Bolts are 10mm, I will torque them according to summary table: 50 Nm
I will do the same for the nut as the control arms are aluminum and if the line I read is the correct one in the table, that it is 50Nm + 40 degrees.
Alex
Alex
- 13 Replies
- 2214 Views
Last post by gnalan
- 11 Replies
- 3195 Views
Last post by theWIFES_S70
- 11 Replies
- 1974 Views
Last post by ericmci
- 1727 Views
Last post by kosh_al
- 3546 Views
Last post by gibbi42
