As stated in the initial post, I removed the plate to find a pool of fuel around the fuel pump. I've cleaned it up since then, and the tank levels have dropped enough to where I'm not getting a pool anymore, for the moment anyways. I've already ordered the gasket since its a cheap and easy thing to cross off the list. If I find any more fuel on top of the tank I'm definitely going to throw some money at the hoses.tryingbe wrote: 27 Aug 2017, 12:50Did you take the plate off and found nothing leaking/wet?Aintezbeincheesy wrote: 26 Aug 2017, 18:02If that's the plate over the fuel pump in the trunk I can't really get eyes on anything other than the fuel pump itself. I'm considering picking up a borescope for my phone expressly to be able to see what's going on there.tryingbe wrote: 26 Aug 2017, 17:46 Remove the fuel pump bypass plate and see where the fuel is coming from.
Fuel leak. Need to pick some brains.
Aintezbeincheesy
- Year and Model: 1994 850T
- Has thanked: 2 times
PeteB
- Has thanked: 57 times
- Been thanked: 11 times
I filled up and it dripped at the gas station, drove 1-2 miles home and it only dripped
slightly in the driveway. Added half a gallon and it was wet around the fuel pump - I
had replaced the fuel pump in the winter and was not able to fully tighten the ring,
tightened it about half a turn more and no more leak. Had to add another gallon or so
and then it dripped a lot from the hose - the hose was split.
Aintezbeincheesy
It seems to only leak when the tank is full. It's dropped to about 15 gallons and it seems to have stopped pooling under the car.jimmy57 wrote: 27 Aug 2017, 11:59 Does it only leak when filled or leak until it gets down to some level?
Sender/pump seal is a full tank leak. SOme hoses can leak due to syphoning effect but will leak until it gets to 1/4 tank.
If it only leaks when runiing and quits when engine is off then it is fuel supply line leak.
Then there is the recall for heat shield attachment points on tank breaking that affects some 850's.
Aintezbeincheesy
For now ive ordered the fuel pump gasket. I'll keep you guys posted. Really appreciate all the responses!
- Year and Model: Many Volvos
- Been thanked: 76 times
There is a recall on the fuel tanks due to cracks that occur around the heat shield. Check your local dealership with the VIN to see if your tank was ever changed. I'm not sure if there is an expiration date on the recall or not but they changed mine on the '94, at no charge, about 5 years ago.
Aintezbeincheesy
Do you think it'd come out with enough force to pool around the fuel pump though?Ozark Lee wrote: 27 Aug 2017, 20:15 There is a recall on the fuel tanks due to cracks that occur around the heat shield. Check your local dealership with the VIN to see if your tank was ever changed. I'm not sure if there is an expiration date on the recall or not but they changed mine on the '94, at no charge, about 5 years ago.
- Has thanked: 311 times
- Been thanked: 817 times
Yes these are all possible causes, even the heat shield issue, you need to check and try to hunt it down. It can leak somewhere else then run over/down to the pump, etc. I would replace the gasket (make sure it seats properly!), leave the cover off, go to the gas station and fill it up. Turn on the key and see if it still leaks - if you can, look right at the pump and have someone else start the car. Or turn it to position 2 so the fuel pump engages and head right back there before starting it, then start it and return to watch while it idles. Does it still leak? Can you tell where it starts from?
Also is the wiring seal still intact? You have to go through each one of the things suggested so far. The order of commonplace seems to be something like gasket, hoses, heat shield or fuel neck, wiring sealant (did I forget any?).
PeteB
You can look up by VIN to find out if the tank recall was done on your car,
ours had it done. I thought that leaked at a much lower level 3/4 maybe?
- 1328 Views
Last post by greg850r
- 9339 Views
- 1126 Views
Last post by FLXC90
- 506 Views
Last post by polskamafia mjl
- 1212 Views
Last post by dyn blin
