US synthetic != actual synthetic though.
But regardless an oil change is due even if semi synthetic is fine for the engine.
Doubt that's part of the issue though.
2001 V70 2.4T Rough growling when accelerating / Volvo code ECM-644A Topic is solved
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
So, this issue is still happening, and I'd like to get to the bottom of it.
The symptoms I'm currently seeing started on 10/30/2017 when I put the car back into service after replacing the oil seals. I had removed and reinstalled all of the timing components at that point. The symptoms include:
- Rough growling from engine during acceleration.
- Increased fuel consumption
- Relatively recent - on 12/26/2017 - Check engine light illuminated with OBDII code P0014 - B Camshaft Position Timing Over-Advanced or System Performance Bank 1 - If this was related to the work I did with the timing components on 10/30, not sure why it would take so long to get thrown.
I put the timeline up here if anyone cares to take a look and share your suggestions.
https://docs.google.com/document/d/15w1 ... sp=sharing
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Cam position codes can be delayed as far as I know so that does sound like it could be the issue. You'd need to trigger a specific set of circumstances for the engine to notice for real or something. The increased consumption also fits.
I'd still say the oil changes have nothing to do with it.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Oil can effect the cvvt cams, mine kept showing sluggish reaction on vida.Rattnalle wrote: 11 Jan 2018, 10:44 Cam position codes can be delayed as far as I know so that does sound like it could be the issue. You'd need to trigger a specific set of circumstances for the engine to notice for real or something. The increased consumption also fits.
Changed oil and filter and the code never came back. It WAS in desperate need, filter looked tragic.
- jonesg
Run the cvvt live test in vida, it pointed me to an oil flow problem , old filter and wrong oil.prwood wrote: 11 Jan 2018, 10:36 So, this issue is still happening, and I'd like to get to the bottom of it.
You never know.
Yeah - that VIDA you just got up and running is going to pay for itself again. While I would have to dick around changing solenoids - you can go in and read out what they are doing and see if they are problem.
- prwood
Ooh, will have to look into that. Thanks for the pointer.jonesg wrote: 11 Jan 2018, 11:51Run the cvvt live test in vida, it pointed me to an oil flow problem , old filter and wrong oil.prwood wrote: 11 Jan 2018, 10:36 So, this issue is still happening, and I'd like to get to the bottom of it.
You never know.
Cars I've owned:
That line gave me a bad C++ flashback.US synthetic != actual synthetic though.
- prwood
Glad I followed it up with a line about pointers!abscate wrote: 11 Jan 2018, 15:26That line gave me a bad C++ flashback.US synthetic != actual synthetic though.
Cars I've owned:
I just saw that and had that same pun-ishment.
Insert <std.io.torture>
- 6837 Views
Last post by prwood
- 32 Replies
- 8347 Views
Last post by SoCalV70T5
- 367 Views
- 25 Replies
- 6798 Views
Last post by wizechatmgr
- 13 Replies
- 9143 Views
Last post by nliutilitt
