Does anyone repair ECC modules?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
misha wrote: 01 Dec 2017, 01:09 Swapping out different ecu(s) like motronic 4.3 to a 4.4 without modification leads to killing of ecc modules,that's one main reason
It does?
Unlikely, seeing as when you do an M4.3 to M4.4 conversion on an ECC vehicle, the only thing that happens is the AC doesn't work, unless you do the proper software mod.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Ac does work...at least that's what i read on forums...but on high acceleration and revving the engine it doesn't cut ac compressor like it's suppose to in order to protect it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 01 Dec 2017, 05:27 You can pick them up from PnP for next to nothing, so repairing them doesn't make sense.
Unless you have a track record and a car to test and warranty them, there isn't much business meat there.o
Comparing with Mattys ABS business, when you read the hacks of people sawing open the cases, bad soldering, and then wondering why the units crap after 3 weeks when they do it themselves, it's easy to understand why buying from him is the smart money.
Hi,
What is PnP and is this all true for the 1998 v70 non turbo FWD also ?
Thanks.
Chuck W
Post by Chuck W »
misha wrote: 03 Jan 2023, 14:14 Ac does work...at least that's what i read on forums...but on high acceleration and revving the engine it doesn't cut ac compressor like it's suppose to in order to protect it.
You have that backwards.
I have an M4.3 car converted to M4.4. I can verify that the AC does NOT work, unless the code mod (or older clunkier hardware mod) is done. AC works perfectly.
if you run an M4.3 ECU in an M4.4 car, that is when the AC compressor will not cut off when needed.
misha
Post by misha »
Why would somebody downgrade software to m4.3 if allready have m4.4?!
I'm pretty sure that posts i read about are for m4.3 to m4.4 upgrade.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Chuck W
Post by Chuck W »
misha wrote: 04 Jan 2023, 08:56 Why would somebody downgrade software to m4.3 if allready have m4.4?!
No idea why someone would. It's just the stated details.
You misremember what you read. You drop an M4.4 ECU into an M4.3 car and the AC will not run, period. You drop an M4.3 ECU into an M4.4 car and the AC compressor will not shut off.
I'm telling you, as someone who has done the conversion and is still using it, converting from M4.3 to M4.4 DOES NOT cause the AC compressor to run all the time. The AC works perfectly with the proper mod, as mentioned.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
MrAl wrote: 04 Jan 2023, 03:48
Hi,
Thanks.
PnP is a junkyard where the customer removes the parts from the car. At this point there are very few P80 cars at Pnp's, and everything made from plastic, rubber, or leather is brittle as a potato chip, but back in the day you could get parts in good condition for next to nothing.
MrAl
Post by MrAl »
850oldschool wrote: 04 Jan 2023, 12:52
Hi,
Thanks.
Hi,
Oh ok i guess that means "Pick and Pull" or something.
Thanks.
plr7285
Year and Model: 850 GLT 1993
Post by plr7285 »
I am attempting to repair an ECC for a '93 Volvo 850 by replacing the blown capacitors. bought an ECC from a junkyard; however it is also has same blown capacitors - though burn is minimal to circuit board. I have a question about a T3GZ diode near the four capacitors that have burned up on the two ECC's I have. On both of my boards, one leg of this T3GZ diode is not connected to the circuit board. I am thinking both legs of the diode should be connected and perhaps the leg became disconnected due to heat? related to the capacitors burning. My friendly volvo parts man gave me a printout showing that only only four ECC's will work in a '93 unless you can get different wire harness. I have 9137402, could also use 6847529, 9144254 or 9144353. Has been hard to locate these part numbers.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
scot850 wrote: 30 Nov 2017, 17:22 Maybe a new sideline suggestion for Matty Moo?
No idea how I didn't see this six years ago. I likely wouldn't have done it then and I absolutely would not do it now.
Anything electrical on an old car is not a fun-filled time for whoever is peddling the parts, as I've discovered in the past few years.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
