The above quote is from the old thread I linked to; it doesn't sound like you can put in a cluster from a '96 or newer (with the green connector) into a '95 or older (with gray connector).Ozark Lee wrote: 08 Feb 2010, 22:00 The '96 and on instrument clusters are different animals. The speed sensor signal is completely different since it was a sine wave signal that comes off of the transaxle on the early models, the later versions had a digital speed signal that comes off of the ABS module.
If I ever get a chance I may try to just insert a diode into the positive side of the sine wave signal and see if the speedometer will work from the old style sensor to the newer cluster. Pulsating DC may be close enough for the speedometer to deal with but the snow is deep and all car related things have been postponed until I have a semi warm and at least dry driveway.
There is also a difference in the ECU, pre-96 N/A versions used the LH-3.2 whereas the '96 and on used the Motronic 4.3 or 4.4. I have both versions of the cars but I have never tried to mix and match the parts. From the schematics I don't think they play well together. The trip computer derives its information from the ECU to give you all of the nifty information on average MPG and real time MPG, etc.
Install trip computer 850 T5 -94
Teddy1975
- Year and Model: 2007 V50
- Has thanked: 1 time
- Been thanked: 7 times
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- Has thanked: 312 times
- Been thanked: 818 times
Good stuff. So I guess you would need to swap in a newer (m4.3 or m4.4) ECU and use the well tested trick of wiring the ABS to the speed sensor. Probably not worth the trouble!
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
In my 1994 N/A I popped in a trip computer from a 1996 and no go. Looks like the only additional feature in the early 850's was the outside temp.
