Very good guess precopster, you are right! I checked and saw that actually the red plastic covering cables lost its elasticity due to cold and were broken. The cables inside were exposed and most probably were touching each other. Both of the connectors cables were in that situation (the shortcut was on the side of the connections which is closer to the REM). I separated them from each other to stop the shortcut.precopster wrote: ↑02 Jan 2018, 14:23 Follow the red cables to where you will find 2 connector blocks close to the REM under the removable foam corner pad. Check the connector blocks on the red cables for corrosion.
The amp readings changed a little but still very high (above 3amp).
Do you think the REM might be damaged because of that shortcut?
