New Volvo owners! XC90 Welcome Topic!
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Re: New Volvo owner!
Post by mrbrian200 »
Snoble4109 wrote: 31 Dec 2017, 17:48 Just purchased a 2005 XC90 2.5t FWD with 123,000 miles.
Good choice. Mind you, in general Volvos are a little maintenance heavy compared to say, an old Toyota Camry, but on the 'low side' compared to many/most other lux models. If you intend to be a happy long term Volvo owner, budget for repairs: 500 for parts, 600 for labor yearly (fluid/filter changes not included in this). Double that it you're using dealer service. If you don't spend it all, bank the extra and keep adding to it.
This should keep you prepared..and happily putting around for anything most 2.5T FWD Volvos are likely to throw at you.
If this is your first Volvo, a bit of advice. Beware of aftermarket parts. You really want to stick to OE/OEM parts on these. For some reason most of the aftermarket parts for Volvos is total crap that either doesn't work right from the beginning or breaks again after 2-6 months. Just don't. I learned the hard way. Every time I'm tempted to use some aftermarket part I get stung again. I'm now at the point where (if it's something rather expensive) I consider it better to install a used OE part rather than a new aftermarket part.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
shiloh51933 wrote: 11 Sep 2018, 07:50 Wow I f'd up, I never to meant to try to highjack this thread...I thought it was a thread for new Volvo XC90 owners. My apologies to the thread starter.
You're fine. No problem. I'll re-title this to make it a new XC90 owner welcome thread.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
mrbrian200 wrote: 22 Sep 2018, 11:22You really want to stick to OE/OEM parts on these. For some reason most of the aftermarket parts for Volvos is total crap that either doesn't work right from the beginning or breaks again after 2-6 months. Just don't. I learned the hard way. Every time I'm tempted to use some aftermarket part I get stung again. I'm now at the point where (if it's something rather expensive) I consider it better to install a used OE part rather than a new aftermarket part.
Made this for you :mrgreen:
Also -> Amazon link
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
ggleavitt wrote: 11 Sep 2018, 09:21 Can absolutely be a thread extension for new owners, it's what the forums are all about.
I'll hope that you've read up on the T6 and the 4T65EV/GT 4-speed transmission. Any idea if this is the original transmission?
To answer your question;
I went through all the paperwork again, the Transmission, radiator, oil cooler lines were all replaced under warranty around 75k. Something about atf leak and I'm assuming this eventually helped kill the Transmission. Anyway it now has 50k on new Transmission and has been serviced twice since it was replaced. I'll probably do another service myself sometime soon.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
