A couple issues with my 96 850 Turbo sedan Topic is solved
Has thanked: 2200 times
Been thanked: 1852 times
Has your temp gauge returned to normal with the new thermostat? If it is not it could be the ECT (engine temp sensor) is also bad or at least the connector which is mounted on the back of the power steering pump and the sensor screws into the bottom of the thermostat housing. Check he connector contacts are clean and the wires are all connected. The connector is known to go brittle with age. If the temp gauge is not reading correctly time the change the ECT. Recommend only Volvo part. There may be an aftermarket brand that works but don't know what brand it is.
Dave in Maine
Year and Model: 2009 S60 2.5T
Been thanked: 3 times
Post by Dave in Maine »
Temp gauge has returned to normal, I get more heat and I'm not burning black any more.
Woo-hoo!
Problem apparently solved.
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
