Bad CVVT solenoid?
Has thanked: 1611 times
Been thanked: 4075 times
s10lowrider1994 wrote: 09 Mar 2018, 10:47
abscate wrote: 08 Mar 2018, 19:12 I think I have a spare know now go back s good one for sale, but I got a freebie paid forward to me. If your in a garden of green nest I can send for a test . If money is tight , paying it forward is right
PM and let’s check part numbers.
I’ve got a used one from ebay that’s supposed to arrive tomorrow. I appreciate the offer though, there’s some good people on this forum.
Let us know if you find them. :lol:
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
About as easy to find as an honest politician =p
2023 Lexus RZ450e -66k
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
Well, the replacement showed up today, p1671 the second I started it. Thanks eBay!
Bad part or the cam belt has slipped out if time.
s10lowrider1994
Is it much of a pain to check the timing? I’m familiar with how it works but I’ve never had this car apart.
JUst put good White out on the marks and turn the engine over slowly to see if the lineup
Best done with spark plugs out
s10lowrider1994
I’ll give it a go tomorrow, I’m hoping I find something wrong so I can quit chasing my tail.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
ECM-6400 (P1671) Camshaft reset valve.
Diagnostic trouble code (DTC) information
D2800346 Condition
Diagnostic trouble code (DTC) ECM-6400 is stored if the engine control module (ECM) registers a fault in the signal cable to the camshaft reset valve.
Substitute value
shutting off the variable camshaft
Possible sources:
Signal too high:
  • short-circuit to supply voltage in the signal cable
    defective camshaft reset valve
Signal too low:
  • short-circuit to ground in the signal cable
    power supply cable short-circuited to ground
    contact resistance
    open-circuit in the signal cable
    open-circuit in the power supply cable
Fault symptoms
malfunction indicator lamp (MIL) lit
uneven idle
Active
Past
s10lowrider1994
Checked timing today, it’s spot on. Thankfully the dealership who last did the timing belt made super obvious marks.
wizechatmgr
That leaves a potential electrical issue assuming both parts are good.
